1993 5.ohhhh
12.97 @140mph
fuel filter
Were is the damn thing? My car started stalling on my in drive and low gears... did it for a while then just stopped. Has been running fine for some reason. I figure I change the fuel filter to see if this problem maybe avoided again. So any help? I've never had to change it before.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
its in between the tank and the rear end on the underside of the car
1993 5.ohhhh
12.97 @140mph
Okie dokie I will go have a look.
1993 5.ohhhh
12.97 @140mph
ohh btw... not all the gas is ganna come out right? lol
it's under your car near your gas tank man.
your going to need a special tool to remove the clamps though
hit the button in your trunk first to depressurise the system first.. and yes a little gas will still come out
#7 | |
1993 5.ohhhh
12.97 @140mph
Ok, it's not between the tank and the rear of the car at all. and by that I mean bewtween the tank and the rear bumper... and it's not sticking out any were else. And why run it tull it stalls?
#9 | |
1993 5.ohhhh
12.97 @140mph
Ok its def located between the gas tank and the differential because I can see it. doesn't look easy to reach. Are u talking about the fuel pump shut off button? will that mess anything up, because the car runs fine now and I can't have that change.
#11 | |
1993 5.ohhhh
12.97 @140mph
All right so the process goes as following...
Press the little red button in the trunk Pull the fuel filter out drain extra gas put new one back in and then press the button again?
#13 | |
1993 5.ohhhh
12.97 @140mph
I'm so excited... well so now I need to go purchase fuel filter tool? I suppose thats what I will ask for at autozone. Your scarring me with the thing about messing up the fuel lines. It looks like I just pop the clips off both sides and remove the fuel lines and let it rain then put the new one in place and put the lines back on then clips back on.
#15 | |
1993 5.ohhhh
12.97 @140mph
allright brb
1993 5.ohhhh
12.97 @140mph
Allright so I got the little clamp tool thingys. So when I press the fuel pump shut off how long to I wait before I start getting the fuel filter off?
press the fuel pump shut off... then go start your car... when it dies from lack of fuel... you can go ahead and take the filter off
Fashion Guru
turn on the car and wait till it shuts off. that way there is no gas in the lines and not much should come out
Fashion Guru
damn you HMUSN
Threads Similar to: fuel filter
| Lucas fuel injector cleaner and fuel filter | Saleen0101 | Modular Mustangs | 0 | September 25th, 2007 04:09 PM |
| Fuel Filter | 06RedfireGT | The Clubhouse | 12 | August 13th, 2007 02:29 AM |
| fuel filter | JASonic | V6 Mustangs | 11 | July 15th, 2007 11:04 PM |
| fuel filter | JASonic | V6 Mustangs | 2 | February 25th, 2007 12:30 PM |
| Fuel Filter 96 GT | Beatz | 96-98 | 1 | September 12th, 2006 06:06 PM |
