DIY cylinder head porting
I was looking at www.sa-motorsports.com at their do it yourself guide to cylinder head porting and i was wondering if this is really as easy as they make it sound? Also, how would doing it yourself compare to something such as the stage 3 cylinder heads from www.moranav6racing.com as far as power is concerned?
i did my lower intake...deleted my IMRCs and filled the holes inside with JB weld and ready to go
just a V6 with a bad belt slip under the hood |
What are the IMRCs? and did you notice much of a difference in performance?
My car ---- (m112 in progress) |
i wouldnt know... a SC will be sitting on top....its on our cars for Trq. purposes....they car sections that are closed for better trq. and open at about 3500rpms.....for more power.....opening them for all the time use will kill low end trq........but with a SC I wont need to be worrying about low end trq....since I have boost to replace it a bit
11.47@120.58
Done several sets of heads, a basic bowl to port cleanup and gasket matching would be the equivelant of maybe a stage 1 port job... say 10-15 horsepower on a 6 banger. Honestly though anything other than that should be left to the pro's with or those companies with CNC machines. Trying to re-design a port or doing major work might hurt more than help if you don't know what your doing.
Well i decided that im going to be the one to take a risk and try something, and im going to attemp to port and polish my cylinder head, and both upper and lower intakes. I will let you all know how it goes.
#7 | |
good luck with that...
¡ʇsnq ɹo uʍop ǝpısdn
yea dude good luck take your time... this is a kinda expensive deal... and you need to take your time and make it perfect and get as much information on it as possible ...
good luck buddy
Yea ive found lots of information, and ordered all the tools i need, except i cant seem to find an upper intake manifold gasket, only the lower one. Is there an upper one, of is the upper one just the cylinder head gasket? I will probally start this project tommorow and hopefully take some pictures and let you know how its going.
1998 Mustang GT
Something that is easy to do: grind the edges down to exactly match the gasket. Sometimes the gasket is bigger than the hole. Simply use a permanate (<-sp?) marker and draw where the gasket goes, then use a small grinding tool to carve the holes out to match the gasket. Do not try to make the entire chamber that big, simply angle the gringing so that it runs into the original port a few inches down.
Off-road X pipe, Magnaflow mufflers, BBK cai, 3.73 gears, ZEX 75 shot (not hooked up), 17in. Bullitts, lowered
Threads Similar to: DIY cylinder head porting
| Head Porting Services | 98BlackBeast | Modular Mustangs | 1 | August 13th, 2007 08:33 PM |
| Stock head and Intake Porting | GizmosMustang | 5.0 Mustangs | 21 | May 3rd, 2007 11:29 PM |
| 3-VALVE RH CYLINDER HEAD | TDog | 2005 - 2010 | 0 | February 22nd, 2007 05:10 PM |
| Head Porting Questions! | 96greenGT | 99-04 | 13 | November 14th, 2006 10:21 PM |
| Head Porting Info | IcantDo55 | 5.0 Mustangs | 3 | September 4th, 2006 11:40 AM |
