Cylinder heads removal help...
Old July 25th, 2007, 08:34 PM   #1
99v6stang's Avatar
99v6stang is on a distinguished road
Okey, so as some of you may have read in my last thread, i am attempting to port and polish my upper and lower intakes, as well as my heads. What i am looking for is a step by step guide to removing the heads. I have guides for the intakes and everything else, but i need one for removing te heads, if anyone could help me out itd be greatly appreciated. Also i hear there is a special tool required to disconect the feul line. If anyone knows about this tool and where to get it, let me know.
Old July 25th, 2007, 08:38 PM   #2
02ponypackage's Avatar
02ponypackage is on a distinguished road
the tool can be bought at pep boys.....as for the heads...i hope your going to do it in one day or have a lot of time on your hands to mess with...at least i have a spare 01 V6 motor i can mess with...
just a V6 with a bad belt slip under the hood
Old July 25th, 2007, 08:46 PM   #3
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
hayness manual maybe can help u out with the head i dunno...
u require alot of time like 02 said
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old July 25th, 2007, 10:47 PM   #4
99v6stang's Avatar
Well, i lost all the points on my licence and im 17 working 3 days a week, plus im grounded, so trust me i have time.
My car ---- (m112 in progress)
Old July 25th, 2007, 10:47 PM   #5
99v6stang's Avatar
Also, i forgot to add, is the tool the same one you use to remove the fuel filter by a chance?
Old July 25th, 2007, 11:00 PM   #6
2000 Mustang V6
no its different.... y u think they name it fuel line removal tool...
lol how u lost all ur points.... ur a bad kid!!!
Old July 25th, 2007, 11:00 PM   #7
2000 Mustang V6
ohh and dude post some pics in ur garage...
Old July 26th, 2007, 01:43 PM   #8
99v6stang's Avatar
I dont understand what i need the fuel line removal tool for, i already took off the upper and lower intakes and havent need any special tool so far...And as soon as im done with this project ill put sum pictures up in my garage, but my car doesnt look so nice ever since my custom buffing job, but thats a story for another day.
Old July 26th, 2007, 02:01 PM   #9
stephen has a spectacular aura aboutstephen has a spectacular aura about
The tool is for disconnecting the injector rail from the fuel line. It is similar to the one for the fuel filter but larger in diameter. You may not need it if you just set the fuel rail aside.
You still need to remove the exhaust manifolds, the alternator/PS bracket and the AC compressor. The AC compressor can be just set aside with the lines hooked up. Then remove the rocker arms and push rods, unbolt the heads and take them out. The head bolts are very tight and you will need a strong breaker bar and probably length of pipe to remove them.
You should get a manual for the details.
Be sure to notice how the head gaskets sit on the engine. The gasket blocks off some water passageways and you have to get it right or the engine will overheat.
Old July 26th, 2007, 04:15 PM   #10
99v6stang's Avatar
Thank you for the instructions, they will come in very handy.
Old July 26th, 2007, 04:53 PM   #11
Also check this out
http://www.supersixmotorsports.com/p...PakInstall.pdf
Old July 26th, 2007, 09:48 PM   #12
99v6stang's Avatar
Thanks for all the help Stephen, and i have a hynes manual , but it doesnt go into very good detail at all.
Old July 26th, 2007, 11:05 PM   #13
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
your welcome
http://www.sharebigfile.com/file/198...oval-docx.html
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Threads Similar to: Cylinder heads removal help...
cylinder heads Blk01ponyGT 99-04 2 October 7th, 2007 08:40 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
Cylinder heads Racinjason81 5.0 Mustangs 0 March 31st, 2007 11:17 AM
Cylinder Heads thewayshemoves 99-04 7 December 26th, 2006 07:35 PM
Broken Key Cylinder removal - Key will not turn, Ideas? Murago 5.0 Mustangs 6 June 21st, 2006 10:35 PM
