#1 | |
the dreaded service engine soon light
ok im all out of ideas. it just wont go away. heres how it all started. ok first i cleaned the throttle body then the iac then i reset the idol screw. tightened the cat back exhaust and after i checked rechecked tightened all the screws and check all the plugs even reset the computer. 2 times just because i thought maybe i did it wrong the first time. now if you listen to the bottom of the car when its running you hear a very faint squeaking noise that goes away when you depress the clutch. when you release it comes back. but it drives better and besides that little noise it sounds better too. does anybody know what the hell happened.
2000 v6
did you go to autozone and have them read your computer... if you do that and any codes come up then you can google the codes and see what needs to be fixed... thats the easiest way to figure out whats wrong!!!
Engine Mods: slp loudmouth catback exhaust, pacesetter h-pipe, k & n cold air intake, jet chip Body and Interior Mods: Saleen front bumber, 18" chrome saleen rims, GT rear bumper and drop zone 2" lowering springs |
when your gas cap is loose it'll pop up too, check that
Click The Picture!
#4 | |
Please get the CEL code read and post back with it then we will make our Recommendations. PS it is very possible it could be something as simple as the fuel cap not seating properly. and PS the MAF or ans you call it the MAS sensor is not 60 bux more like 460 bux just FYI |
dude come to autozone haha ur like a few miles away from me ..i work in the lamont store ill check ur light or u can go to any autozone and theyll rent it out to you lol
My Stallion is Bigger!
It would be impossible to have a service engine soon light as that is exclusive to GM products. To ensure that you are going in the right direction to diagnose the culprit causing your CHECK ENGINE light to come on get your code/ codes read and post them up here so we can better troubleshoot the problem you are having. Also it is a MAF Mass Air Flow sensor not a MAS
#7 | |
ok thanks guys i appreciate all the help.
i'll try and get to the lamant store. i think i know where you are. whats your name so i know who to ask for. when would be a good time to come in? ive heard mas and maf i just know there the same thing. and yeah the gas cap was the first thing i checked. but that wasnt it.
#8 | ||
#9 | |
48.47@ 12.58
Re: the dreaded service engine soon light
#10 | |
no stick
48.47@ 12.58
that's called clutch chatter my friend.
it's normal. when you have your foot slightly on the clutch does it vibrate a tad?
#12 | |
48.47@ 12.58
^ clutch chatter is normal in mustangs.. excessive clutch chatter is a throw out bearing.. and I didn't notice him saying that he had a cel.
#14 | |
#15 | |
48.47@ 12.58
didn't catch the thread title.. my bad..
your clutch can in fact chatter at an idle as well.. stock flex plates suck. it's a high pitched sound that.. nvm .. you know what it sounds like obviously.as far as the chatter.. the best I can do for you with the noises is to recommend lubricating the shift linkage and check the shift cable. The shift cable has a small seal, much like a valve seal, on the end to keep water and dirt out. If this seal goes bad then the water gets in and the shift cable starts rusting, usually resulting in a squeaking type noise.
#17 | |
#18 | ||
#19 | |
http://napaonline.com/masterpages/NOLMaster.aspx?PageId=470&LineCode=NEC&PartNumber= MAF650014&Description=Mass+Air+Flow+(MAF)+Sensor+-+New |
48.47@ 12.58
save yourself a few bucks.. people sell them for around $100.00 on svtperformance...
Threads Similar to: the dreaded service engine soon light
| Service engine light wont go away!!!! | dgt_mustang | V6 Mustangs | 59 | July 10th, 2007 06:43 PM |
| Dam Service Engine LIght on AGAIN!!! | jrfan4life | 99-04 | 31 | March 30th, 2007 10:11 PM |
| Service engine soon light blinking..... | jrfan4life | 99-04 | 26 | March 20th, 2007 10:18 AM |
| Help Me (Service Engine Light) | sgrcltpunk | 99-04 | 3 | March 10th, 2007 12:57 AM |
| SERVICE ENGINE SOON LIGHT | ROUSHME | V6 Mustangs | 4 | June 15th, 2006 12:31 AM |
