synthetic oil ?
Old July 31st, 2007, 12:28 AM   #1
Blackbeauty v601's Avatar
2001 Mustang 3.8
Blackbeauty v601 is on a distinguished road
synthetic oil ?
Ok well i drve a beautiful black mustang its a v6 3.8L and my friend drives a celica he uses full synthetic oil and he told me its makes a huge difference in the drive of the vehicle i know its alot better but does any one think that its a change that should be made or is it just a change that u do just cause you feel like it. should i go full synthetic or stay with regular oil. any one please leave some comments..
Old July 31st, 2007, 12:33 AM   #2
SPF0percent is on a distinguished road
Send a message via AIM to SPF0percent
some synthetic oils claim to gibe u about a 5hp gain just from a oil change...how IDK but ive seen and felt results from using royal purple and lucas full synthetic....also full syn...cost about $7 a qrt...so oil changes run to about $50 for the filter n all....but u also dont have to change ur oil till 7000 miles instead...its better for ur engine because of special blends and what not in it..correct me if iam wrong but i think thats pretty much it...u get what u pay for.
Old July 31st, 2007, 02:18 AM   #3
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
theres no HUGE difference
its just a really good idea and better for your engine to use synthetic oil
the oil is the life of the car
btw the leading cause for engine failure to most cars is the oil pump...with synthetic oil the problem is decreased
[SIGPIC][/SIGPIC]
Acmillr loves me
Old July 31st, 2007, 07:49 AM   #4
Ole Yeller is on a distinguished road
the only real difference is that synthetic oil doesn't break down.
how does this help? well oil when subjected to heat and friction (which generates heat) can either burn (which they both do) or break down (only conventional or dino oil)
if your the type of person that no matter how you drive you change your oil every 2.5K to 3K miles. then conventional oil is really going to perform pretty much the same, but if your one of those "I drive it like i stole it, i change my oil every 5 - 10K miles" then go with synthetic.
oil isn't your main problem, it's the filter most filters only block particles of 11 microns or bigger, when the majority of particles that cause engine problems are 10 microns or smaller (when the collect they create "gunk") so basically when it comes to oil, go with whatever you feel, BUT DO NOT CHEAP OUT ON THE FILTER!!
check this site. www.bobistheoilguy.com and it will tell you everything....
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
Old July 31st, 2007, 09:27 AM   #5
crashnebula's Avatar
2000 Mustang v-6
crashnebula is on a distinguished road
ROYAL PURPLE FTW!!!!
2000 V-6 Coupe Mustang, 17 inch rims, custom hood, exhaust is done!!
Old July 31st, 2007, 10:37 AM   #6
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
like yeller said syn oil wont break down, but it is slightly thinner than conventional oil a 10w30 convention will feel heavier than a 10w30 syn, but in extreme heat or after a long time of use conv, oil will become a 0weight where syn. will be the same viscosity as when you bought it.
NCMM #9
Old July 31st, 2007, 11:05 AM   #7
has anyone tried a heavier weight than just like 10/30 or so?
i used to only run 20/50 in my truck and my nissan. in SWFL it doesn't really get cold enough to need anything with a cold weather viscosity rating because even in the winter it RARELY gets below 40 for a few hours at night.....
plus the thicker weight would drown out some sound from valve tap...
thoughts?
Threads Similar to: synthetic oil ?
Synthetic Youngin V6 Mustangs 43 August 31st, 2007 12:02 PM
conventional to synthetic WilltheThrill 99-04 18 August 23rd, 2007 10:30 PM
Synthetic or Regular Oil PaperCross General Tech 28 May 2nd, 2007 07:31 PM
Synthetic vs. semi synthetic vs. standard stagecrewgod General Tech 2 March 29th, 2007 10:33 AM
Synthetic Oil TedG954 2005 - 2010 33 March 5th, 2007 12:23 PM
