1998 Mustang GT
Spark Plugs
Im going through the process of adding a Scremin Demon coil. Im wanting to get new spark plugs as well. Can you recommend some plugs that will work with the new coil? Im gonna use MSD 8.5mm wires and the plug gap will be about .06 or .065. What brand would you recommend? Any prices and part numbers would be nice.
Off-road X pipe, Magnaflow mufflers, BBK cai, 3.73 gears, ZEX 75 shot (not hooked up), 17in. Bullitts, lowered
RLY SRS
PM Chris Torres about this...He has a full list that he has compiled with the V6 plugs...He also can give you the part numbers at some of the reailers I believe...
1998 Mustang GT
Ok. Thanks man.
Autolite coppers at .065 would work the best. the larger gap will give you a truer spark at lower rpm and idle this will allow better combustion and this giving you more fuel efficiency and power in the low end its not going to be like 15 hp but it will give yah a lil bit of a kick.
i have the exact same set up
only im gapped at .054 the propper sized gap. i would go at least .060 because my lower RPMS accel like shit get some autolite coppers like jug said. the part number is 765 or NGK tr55 tr55 might come up with a few different plug numbers at your autopart store. if you'd like i can get and sell you autolite probably the same price or cheaper then your auto store and copper plugs i get for under $2
#6 | |
Threads Similar to: Spark Plugs
| spark plugs | drivewith2feet | V6 Mustangs | 27 | September 7th, 2007 07:44 PM |
| Do I need different spark plugs? | YNOT | 5.0 Mustangs | 5 | June 5th, 2007 07:31 PM |
| Can Someone (Pic Of Spark Plugs) | Luvdmustang | 96-98 | 4 | January 26th, 2007 02:12 AM |
| spark plugs? | rednsilver91 | V6 Mustangs | 24 | January 22nd, 2007 11:35 PM |
| Spark Plugs | Drgnracin72 | 99-04 | 17 | November 13th, 2006 03:10 PM |
