Parts cleaning for engine rebuild
Old August 4th, 2007, 09:36 PM   #1
Buttaz's Avatar
96 v6 MODDED
14.6
Buttaz is on a distinguished road
Send a message via MSN to Buttaz
I think the title is pretty self explanatory, but here it goes anyways. . .
I'm rebuilding my '96 3.8 to replace a blown head gasket. The problem is, theres burnt on coolant pretty much everywhere. Mainly I'm worried about the interior of the engine, but I'd really like to clean up the outside as well. I'd like to pretty much shine up the entire head on both sides, and the lower intake manifold. Is there any way I can clean the intake, exhaust, and coolant passageways? I've wot some EngineBrite engine cleaner, and some carb cleaner for the hard to get stuff, and I've been scrubbin away with a tooth brush for like 3 days, ant what I can reach looks ok, but I need a way to like de-grease the entire head. Is there a solution or something that i can dip it in to clean the entire part?
Old August 4th, 2007, 09:38 PM   #2
TheUNZippee!'s Avatar
As long as a surface is not aluminum, use a small wire wheel in a drill for the external surfaces of the heads & block.
Also look for a product called Gunk. It rocks.
Originally Posted by My Wife
Old August 4th, 2007, 09:39 PM   #3
Gunk: Look For The Degreaser
Old August 4th, 2007, 09:41 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
have it powerwashed and steam cleaned.
... it costs around $50.00 and it make it look like it has ten miles on the motor.
Old August 4th, 2007, 09:42 PM   #5
Yeha powerwashing is also grate for cleaning shit. So to speak.
Old August 4th, 2007, 09:55 PM   #6
Buttaz's Avatar
96 v6 MODDED
14.6
but i thought you weren't supposed to clean engine parts with water because of rust?
what are your thoughts on electric cleaning? i remember seeing it on the speed channel.
something about dumping the part in a bucket of water and baking soda, then hooking up a battery to it and all the dirt flows off of the part
Old August 4th, 2007, 09:58 PM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I personally haven't seen that...
but I have had an engine cleaned before and they did an outstanding job.. and remember... if it's not you doing the cleaning and something breaks... it's their fault and they have to pay for it.
water it's going to hurt your outside engine parts.
salt will.
Old August 4th, 2007, 10:09 PM   #8
It's also handy to have a parts cleaner, like this baby here: WASHER!
Old August 5th, 2007, 11:02 PM   #9
stephen has a spectacular aura aboutstephen has a spectacular aura about
If the heads are off the engine, I would just give it to a machine shop to clean up and also have them do a valve job and surface the head gasket surfaces.
A machine shop would soak the heads in solvent and probably also shot blast them. I have usually done a preliminary cleaning first. One way is to soak it with Gunk and hose it off. Another option is to use paint thinner and rags to get most of the dirt off the outside and then power wash it. I have a power washer for other purposes and it does a good job of cleaning engine parts.
Threads Similar to: Parts cleaning for engine rebuild
Engine Cleaning? Snipe061 Visual 14 September 22nd, 2007 12:04 PM
Parts cleaning for engine rebuild Buttaz General Tech 2 August 10th, 2007 12:57 PM
Engine Cleaning tnknepp Classic Mustangs 4 July 23rd, 2007 06:48 PM
Cleaning engine MustanG_guy17 99-04 14 April 20th, 2007 09:22 PM
Cleaning Engine themav46 V6 Mustangs 15 October 9th, 2006 07:23 AM
