Fuel Rail leakage....
Old August 5th, 2007, 12:03 PM   #1
lwhitetrash88l's Avatar
2004 Mustang
lwhitetrash88l is on a distinguished road
Send a message via AIM to lwhitetrash88l
yeah.....you know how on the passenger side of the car the fuel rail has this little valve that looks like a tire valve where you would like insert air into the tire? im starting to see like nasty gooey secretion around it....im assuming it gas leaking out of it but what should i do about it? unplug the fuel pump, depressurize the fuel rail then try and tighten it? or no? any input guys? thanks
Old August 6th, 2007, 11:20 AM   #2
2004 Mustang
Old August 6th, 2007, 11:34 AM   #3
CyberPrey is on a distinguished road
I believe the fitting you are speaking of (without a photo) is there in order to hook a Fuel Pressure guage into the system for diagnosis when you go into a shop. It is similar in appearance to a tire valve, but it is not the same.
To be honest, I am not sure if the core can be changed like a tire valve core. You could check with the dealer on that, and if it can be changed, do what you had previously stated and depressurize the system, and change it out. I would also highly recommend getting the cap that goes over that valve when not in use in order to keep dirt/gunk out of it.
Old August 6th, 2007, 05:58 PM   #4
2004 Mustang
yeah thats the area im talking about but its not the core of the valve its leaking out where the valve screws into the rail itself....and i didnt even know theres a cap for it....where might i find a cap for it? aside from the junk yard
Old August 7th, 2007, 06:28 PM   #5
2004 Mustang
Old August 7th, 2007, 09:20 PM   #6
TurboLX's Avatar
1988 Mustang LX Turbo
The Schrader valve is what it's called
you can get a cap from your local part's store
Old August 8th, 2007, 11:11 AM   #7
2004 Mustang
awesome thanks man
Old August 8th, 2007, 02:52 PM   #8
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Like turbo said shrader valve, go to auto zone and they can help you out.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Threads Similar to: Fuel Rail leakage....
Some questions on DTC P0190 (Fuel rail pressure sensor) throwedoff 99-04 14 September 6th, 2007 10:46 PM
FUEL RAIL PROBLEM oasr87 V6 Mustangs 4 July 7th, 2007 03:09 AM
Fuel Rail Hose? lwhitetrash88l V6 Mustangs 3 May 25th, 2007 10:30 AM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 07:48 PM
