seafoam...
i was kinda skeptical about it the 1st time..a friend of mine with a 02 GT just used it and said it was better after....but its through the vacuum line ? others i heard said it was the gas tank...but he said make sure you dont put it in the gas tank.....so idk but with 80,000 miles I'll try it...and 7$ is w/e....my car has been running a on the weaker side maybe its the 100+ degree heat but I'll try this anyways
just a V6 with a bad belt slip under the hood |
48.47@ 12.58
do it.
It'll def. make your car feel better.
Cigar Assassin
can anyone take a pic of the vacuum tube that I am supposed to use when I use it on my 04 GT. i have the bottle of seafoam sitting in the garage, but I just haven't been able to find out which tube to use
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox ![]() |
48.47@ 12.58
put in in the pcv line not the break booster line or u will only get cyl 1-3 with it. also make sure the car is running when u do it or u wont be able to crank the engine cuz seafoam dont compress like A/f u will get water lock to to speak
could someone explain what exactly does seafoam do, where can I get it, and how do you use it?
I watched that video but I don't really get what the guy's doing...
i didnt bother getting it...
seafoam is a cleaner.... the reason the car in the video is smoking is because all the built up carbon in the motor is being broken off the cycl walls and burnt. basically cleans your engine...
sea foam is basically just mineral spirits.... run it in your oil for 100 miles then do an oil change and you'll cean the crankcase, run it in your fuel as an injector cleaner, or through a vac hose as an engine cleaner... it's multipurpose
So this guy and his friend were like wanna race? i was like :stupid- the light turned and we and I went and his friend was like you got and I was like and went home and his wife. The End
I know what is supposed to do and reason for smoke...but F it
ok then, don't use it...
i'm pretty sure the nice folks over at seafoam are crying about it.
and im sure your sarcasm is appreciated to those who care
48.47@ 12.58
02ponypackage.. only 2 more posts
I have never heard of this stuff before. Interesting.
Yeah I know...1 more
#15 | |
oh and congrats on 2K posts!
#17 | |
Cigar Assassin
48.47@ 12.58
no problem man
#19 | |
get the seafoam man...seriously none of that other bullshit does anything
ive tried gumout...GARBAGE...techron...not good...only havent tried lucas but seafoam is actually pretty decent i put it in my oil, gas and brake booster then pcv
Threads Similar to: seafoam...
| Seafoam? | MustangMatt96GT | The Clubhouse | 21 | October 20th, 2007 04:30 PM |
| how do u seafoam? | ricerraper33 | V6 Mustangs | 11 | October 8th, 2007 08:19 PM |
| seafoam | SilverGT04 | 99-04 | 11 | September 12th, 2007 01:48 PM |
| Seafoam | mustangmanic | 99-04 | 25 | July 17th, 2007 01:24 AM |
| how much seafoam? | energiesource | 99-04 | 3 | June 21st, 2007 03:48 PM |
