engine problem
car is puttering like its idleing very ruff but the rpm hand isnt moving also getting a slight whine noise when i accelerate one shop told me it was the 02 senors one guy and another told me the injectors needed cleaning not to mention that my ecu is not spitting out any codes when hooked up mechanic told me its like someone erased all the codes
at a loss need it fixed asap will be leaving back to school in about a week and the car rides like shit.
2000 Mustang V6 5spd. (deceased) 1988 Monte Carlo SS (cruiser) 1993 Mustang GT 5spd (bruiser) |
Always check the basics first. Start with spark. Are all cylinders getting spark? You can buy a spark tester at most parts stores.
Agreed maybe stick some seafoam in your tank and fill your tank with gas that will help clean out your fuel injectors.
Mean green Import stomping machine |
do a tune up and seafoam ur ride. plugs, air filter fuel filter maybe wires and an oil change.
had the wires checked yesterday and sensors added some injector cleaner concentrated. i guess i just have to let the gas all run out should i notice the difference in a few days or just by the end of my tank of gas.
should notice with in a few dozen miles
fixed problem, spark plug wire was resting on top of the header fried through made cycl. #3 misfire causing putting and strain on motor plus obvious loss of power wen needed. not going back to the other shop anymore injectors are fine guy probably didnt even check engine.
#9 | |
Threads Similar to: engine problem
| Engine flooding problem | fastford3388 | 5.0 Mustangs | 3 | August 13th, 2007 10:33 AM |
| Problem with engine | troy1000rr | General Tech | 6 | June 6th, 2007 06:25 PM |
| Engine problem? | gregkelley | 5.0 Mustangs | 5 | April 14th, 2007 08:22 PM |
| ENGINE PROBLEM | criptez | V6 Mustangs | 1 | April 12th, 2007 11:12 PM |
| My Check Engine Problem | OcOnnor220 | 99-04 | 9 | February 8th, 2007 01:36 PM |
