How do I Replace the engine belt?
I need to replace the belt on my 97 mustang. engine is a 3.8. How do I work the tensioner to remove the old belt?
¡ʇsnq ɹo uʍop ǝpısdn
you want to pull the belt tensioner up with a wrench... its kinda odd... put the wrench on the end of the tensioner... and pull up... it spring loaded so it will come up with some strength then while its slakced a bit slip the belt of the water pump... it has no ridges its the easiest
then put it back on the same way you took it off
![]() Put a 3/4" (18mm) socket on the tensioner pulley and turn counter clockwise to release and remove the serpentine belt.
Thanks
Thanks I'll try it.
It worked.
thanks it worked fine.
Threads Similar to: How do I Replace the engine belt?
| 302 in my 95 with V6 Replace Engine mounts? | dreamr | General Tech | 0 | October 30th, 2007 08:19 PM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 06:09 PM |
| 5.0 to replace 3.8 | big_stroke | V6 Mustangs | 24 | January 31st, 2007 08:10 PM |
| Replace Them | psycho bob | 2005 - 2010 | 1 | September 25th, 2006 02:06 PM |
| 427 to replace 232 | 94pacecarSVT | V6 Mustangs | 5 | August 31st, 2006 07:03 PM |
