A/C and spark plug questions
Hi again. posted here some time ago about trany problems and got some good help so thought i would check with you guys again for my new "problem" i have a 1999 V6 3.8 with and auto in it.
A/C first. k so my A/C problem is i can have my A/C turned off...just have it set to floor and dash but turned to full cold air and no matter how hot it is out side it feels like the A/C is on after a bit. second A/C problem is if i turn on the hot air the windows fog for a second and there is a wet feeling to the air but fades fast ideas? and the last A/C problem (first car with A/C so just wondering) is it normal to find water under your car....not just a bit but a LOT...today at one stop my car dropped close to a cup of water on the ground and yes it is water. any thoughts on this? now for the spark plugs. how the heck do you get to the left side plugs with out ripping the car apart to get to them? the back one is so well in there i can't even see it lol that said i read on a few posts that a gap of .065 might help with low end power a bit (something i find my car lacks some times) also i'm new to mustangs is there any general care and upkeep i should know of? sides the normal stuff |
#2 | |
the a/c is normal..it takes a bit to cool the air.. yeah depending on how much time u can get even a gallon of water on the car.. depending on the outside temp ur windows will fog cold outside+hot inside car =fog and same with hot outside+cold inside car....
and idk from what angle ur talking... i'm a lil confused are u talking of the part where the intake its?
ok
for spark plugs unless you have upgraded wires and coil stick with .054 gap you'll want to run t-6 or autolite copper part #765 the left side(drivers side) is probably the easiest side if you ask me.... the passenger side is a lil more of a pain...just gotta remove the intake and put your hand in tight uncomfortable spaces
#4 | |
get what chris reccomended dont buy bosh cause u regret it..
ah yes sorry was talking about the passenger side plugs (left side when you are working on the car) and thank you for the info
the A/C thing was kind of worrying as my last car did the hole fogging the window thing and it was a shot heater core so when i saw i bit of fog i kind of scared my self (last car was a pain to fix) any tips on easy ways to change the plugs is welcome lol not looking forward to this project |
Threads Similar to: A/C and spark plug questions
| spark plug gap...wat does it need to b? | VSR13 | V6 Mustangs | 7 | January 30th, 2008 05:48 PM |
| spark plug gap | white93pony | 5.0 Mustangs | 8 | October 13th, 2007 10:51 AM |
| spark plug ?'s | tgk | 94-95 | 1 | August 25th, 2007 07:29 AM |
| Spark plug gap? | 8A_Honda | V6 Mustangs | 5 | July 6th, 2007 01:43 PM |
| Spark plug gap | flattusmaximus78 | V6 Mustangs | 27 | June 30th, 2007 12:46 AM |
