#41 |
hey HMUSN got a friend with a 70 opel gt could that motor build up with his rear diff?
![]() Mod list got too long for my sig...check my garage for complete list of mods
#42 |
48.47@ 12.58
it would need a custom drive shaft .. new holes for motor mounts .. and that's probably it.
#43 |
ok thanks for the speedy response
#44 |
48.47@ 12.58
yup.
#45 | |
Re: Blew up my engine and need a new one....
As to the damage. If that was what happened, you probably have one or more bent valves and at least one destroyed piston/rod assembly. It is good practice to turn the engine a few revolutions by hand before starting it up to check for piston to valve interference. I would recommend using the stock engine. You will need to remove it and disassemble it to see exactly how bad it is. If there is extensive damage you may want to start with a new core. |
#46 |
you can get the block from an f150
or if you wana be safe buy a short block from rpm, ssms, tom morana... then put back on your cam, heads, intakes, and waterpump, power sterring everything else
Threads Similar to: Blew up my engine and need a new one....
| I blew the motor | cams-shelbycobra07 | 5.0 Mustangs | 125 | May 6th, 2008 02:25 PM |
| I think I blew out!!!! | Top Gear | Audio/Video | 21 | September 26th, 2007 03:47 PM |
| Blew out the rear end | 69fastback | Classic Mustangs | 6 | August 22nd, 2007 09:13 AM |
| Blew it and knew it.....! | Sickstick | V6 Mustangs | 23 | May 27th, 2007 02:06 AM |
| Blew Something | JRubin2000 | 99-04 | 11 | November 2nd, 2006 07:01 PM |
