1999 Ford Mustang V6
99-04 3.8L smog pump (secondary air injection)
Failure Codes:
P0411: The PCM has determined that the flow detected in the secondary air injection system is incorrect for the current engine operating conditions. P1414: SAI System Monitor Circuit High Input Failure Causes: - due to poor design of air inlet tube the smog pump tends to take in water/moisture which inturn sits in the bottom of the rubber cup that surrounds the motor and causes it to rust. - electric motor bearing failure, causing seizing.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
inside smog pump rubber cup showing rusting
99 mustang 3.8 smog pump
another view
Threads Similar to: 99-04 3.8L smog pump (secondary air injection)
| smog pump | skid6 | 5.0 Mustangs | 4 | October 9th, 2007 09:06 PM |
| smog pump help | stangzilla 331 | 5.0 Mustangs | 2 | March 11th, 2007 10:04 PM |
| Smog Pump | jcc1991 | 5.0 Mustangs | 3 | September 4th, 2006 12:51 PM |
| smog pump | cali 5.0 | 5.0 Mustangs | 3 | July 24th, 2006 02:03 PM |
