Changed spark plugs, and found some problems.
Old July 16th, 2006, 06:01 PM   #1
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
Well the first problem, is that was the hardest engine to change spark plugs on. But seriously my spark plugs wires were not in good shape. The cups on them were bent or didn't get a good hold of my spark plugs. Also my spark plugs contacts, and nut was rusting right into my engine. So I changed my spark plugs out, and then decided it was time to upgrade those spark plug wires. Well I found these from www.v6mustangstuff.com
A "Screamin Demon Coil" and "Screamin Demon Livewires" for 94-01 v6 mustangs. I bought them today, and hopefully that will make me a much happier camper for future mods. here is a pic of the set and the description from v6mustangstuff.com
For the coil pack
Mustang V6 owners can now increase the spark intensity of the 3.8 liter ignition by installing Performance Distributors' new Screamin' Demon Coil! This is the first high performance coil available for the 1994-2001 Mustang V6 engines. The Screamin' Demon Coil is designed to produce a longer duration spark and allow plug gaps to be opened up to an astounding .060" - .065". This will burn the fuel mixture more efficiently for increased performance and better fuel mileage. This will also help spark plugs stay cleaner longer. In addition, the intensity of the Screamin' Demon's spark does not drop off as the rpm's increase, which is common with stock ignition systems. In a series of 0-60 mph tests, we improved our E.T. an average of .33 seconds over the stock ignition coil! That's performance you can feel in the seat of your Mustang V6! The Screamin' Demon Coil is epoxy filled, leading to improved heat transfer and vibration resistance. The Screamin' Demon Coil is easy to install and mounts in the original equipment location.
For the Livewires
After bolting on the Mustang V6 Screamin' Demon Coil, you'll need a set of "LiveWires" spark plug wires to deliver the hotter spark to your plugs. LiveWires come with space age, heat resistant sleeving to provide protection from exhaust heat. The sleeving is heat treated glass braid and is non-flammable and non-corrosive to chemicals. LiveWires are custom fit - no assembly is required. Each wire is numbered at each end for the correct cylinder. LiveWires have a durable and long lasting silicone jacket and insulation. Spiral wound core prevents electronic interference - no radio noise or computer interference. Available in blue, black, red, yellow & purple.
I should have a write up about them once I install them.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old July 16th, 2006, 06:21 PM   #2
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Can't wait!
Old July 16th, 2006, 10:33 PM   #3
Zoolander
iTrader: 5 reviews
Neither can I. I'm actin like a kid waiting for christmas. Shoulda saw me at the car aution the other day. NO MUSTANGS!!!!! I was upset. But I was like a kid in a candy store starting all the cars, revving them, looking at the engines. It was so much fun for me.
MM Cobra Club #18
Team Tini Racing
Old July 17th, 2006, 06:45 AM   #4
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
cool, let me know how it turns out, i am currently running some msd 8.5mm superconductor wires and they were a big differance over stock.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old July 22nd, 2006, 11:48 PM   #5
Zoolander
iTrader: 5 reviews
I'd let ya know how it turns out if it gets here. I'm getting impatient. The site doesn't give you a tracking number. Hopefully they come in Monday or Tuesday.
Also when I do get them I know I should put anti seize on the end caps for the spark plugs but what about the part that plugs into the coil pack should I put anti seize on them too?
MM Cobra Club #18
Team Tini Racing
Old July 22nd, 2006, 11:50 PM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
The worst part about buying something is waiting for it to come in the mail...
Facebook
Google+
Old July 23rd, 2006, 09:11 AM   #7
Roadhawg is on a distinguished road
That reminds me of my Russian mailorder bride. But that is a whole other story......................
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old July 23rd, 2006, 12:33 PM   #8
NO! NOT ANTISEIZE!! Use dielectric grease. If it doesn't come with the wires, you can pick up a small tube at advance or autozone.
88 Mustang Coupe
www.rickscarcare.net
Old July 23rd, 2006, 03:23 PM   #9
yeh sometimes you can also find the dielectric grease in small sealed packages near the cash register
Old July 24th, 2006, 10:10 AM   #10
artisan00 is on a distinguished road
what kind of performace gain does replacing that kind of stuff give you?
Old July 24th, 2006, 10:19 AM   #11
Zoolander
iTrader: 5 reviews
Not a large one. Like what the little description said they were .33 seconds quicker than stock. So I know I prob won't even get that much off, but hey it will be more useful for mods later down the road.
MM Cobra Club #18
Team Tini Racing
Old July 24th, 2006, 10:27 AM   #12
AtlanticBlue99's Avatar
14.79 @ 92.15
.33 is a lot faster for the e.t.- especially if they were doing a 0-60 run. Hell, my 4.10s and t lok shaved .6 off my 1/4 mile e.t.
ModdedAutos
1999 Mustang V6
Old July 24th, 2006, 11:18 AM   #13
Zoolander
iTrader: 5 reviews
For drag racing. I'm more into open track so .33 is not that large for me in the big run. Yea, .33 with one part off a track time is awesome, but also I'm willing to bet that I won't see those kind of times shaved with this part since most companies times almost never match customers.
MM Cobra Club #18
Team Tini Racing
Old July 24th, 2006, 01:05 PM   #14
OTreborO is on a distinguished road
Well Yeah
Originally Posted by turp
Can't wait!
Well Yeah, My Daddy has a Cyclone, and.........................
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old July 24th, 2006, 01:08 PM   #15
Reving the engines
Reving the engines:::
You rev the engines at the car auctions in Va and they make you leave. No crap, they have police at the auction and if you rev the engine, you are outta there.............................................
Old July 24th, 2006, 02:05 PM   #16
Zoolander
iTrader: 5 reviews
It was the day before the auction. So they let you look at the all the cars, and encouraged you to check the engines out, and do the best visual inspections possible, and allowed to rev the engines of the car. I know what happens in VA since I live here as well.
MM Cobra Club #18
Team Tini Racing
Old July 26th, 2006, 10:48 PM   #17
Zoolander
iTrader: 5 reviews
Got my parts in today, and gonna try to put them on tomorrow after work. Came with Dielectric grease. Now I put this on the end where i put the wires onto the spark plugs I know, but do I also put this where I plug the other ends into my coil packs?
MM Cobra Club #18
Team Tini Racing
Old July 26th, 2006, 10:49 PM   #18
14.79 @ 92.15
Let us know how your new coil pack and wires turn out. I have stock wires on a stock coil pack, and never considered changing it...
ModdedAutos
1999 Mustang V6
Old July 26th, 2006, 10:58 PM   #19
turp's Avatar
3 feet...
Mallory is the best when you decide to upgrade! FRPP makes a 9MM plug wire set for the V6
Old July 26th, 2006, 10:58 PM   #20
Zoolander
iTrader: 5 reviews
Trust me. I will def let everyone know how they turn out. Hopefully by tomorrow evening. Somehow I gotta go to sleep and get to work at 7 tomorrow morning. It's gonna be a long day tomorrow. I'll let everyone know how they turned out as soon as possible.
MM Cobra Club #18
Team Tini Racing
Threads Similar to: Changed spark plugs, and found some problems.
Spark Plugs 2000Mustang V6 Mustangs 5 July 31st, 2007 03:48 PM
spark plugs? rednsilver91 V6 Mustangs 24 January 22nd, 2007 10:35 PM
spark plugs bcp5008 V6 Mustangs 8 December 20th, 2006 08:14 PM
spark plugs speed4goal 5.0 Mustangs 4 December 13th, 2006 08:25 AM
Changed Plugs And Wires On A Camaro Today mdvaldosta All Other Vehicles 8 July 4th, 2006 06:36 PM
