T/O Bearing....
Old August 16th, 2007, 11:05 AM   #1
lwhitetrash88l's Avatar
2004 Mustang
lwhitetrash88l is on a distinguished road
Send a message via AIM to lwhitetrash88l
T/O Bearing....
Hey guys, im gonna replace my t/o bearing and i was just curious if you guys could give me a little walk through on how to do this, whats involved, what kind of tools i need, how long it will take etc. etc. input would be greatly appreciated, thanks!
Rich
Old August 16th, 2007, 03:12 PM   #2
2004 Mustang
anyone?
Old August 16th, 2007, 03:16 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
4-5 bolts hold the trany in place--remove them after you disconnect the drive shaft. Make sure back of the engine is supported . Unbolt the rear transmission mount and remove transmission. Need to take the shifting lever off. 8-9 bolts and remove the bell housing after you disconnect the clutch assembly. 6-bolts on the pressure plate--remove and the clutch disc will fall out... The bearing is on the transmission sleve...
Old August 16th, 2007, 03:26 PM   #4
02ponypackage's Avatar
02ponypackage is on a distinguished road
i think mines messed up too..every time i let it out i hear a click sound...i so when i upgrade my clutch it should go away with a new throwout bearing if thats what is making the noise...which im sure it is..because when the trans was out i saw a metal ring bent...so it didnt engage disengage with the bent lip catching making a noise
just a V6 with a bad belt slip under the hood
Old August 16th, 2007, 11:31 PM   #5
2004 Mustang
so is this something i should be able to accomplish? and also can i do this without a lift or no?
Old August 17th, 2007, 01:15 AM   #6
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
i would at least have a jack!
that'd be hell with out one on the ground
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 17th, 2007, 11:32 AM   #7
2004 Mustang
well yeah im thinking like car ramps on the front end....the only type of majopr work i have done are the headgaskets on my car....is this harder than that? and if so do you think i can accomplish it on my own? lol
Old August 17th, 2007, 12:38 PM   #8
stephen has a spectacular aura aboutstephen has a spectacular aura about
Car ramps could be used. I prefer jack stands. For safety you should have a hard surface such as a concrete driveway or garage floor to work on.
A transmission jack would be very helpful and can be rented.
Basically you need to support the back of the engine with a jack and the transmission with a trans jack. Unbolt everything and pull the transmission back.
I would say it is easier than the head gasket job.
Unless you are very short of money it would be better to replace the clutch as well as the t/o bearing.
Old August 17th, 2007, 12:52 PM   #9
2004 Mustang
yeah im really really tight on money and thanks for the info stephen! any other advice or heads ups?
Old August 17th, 2007, 01:23 PM   #10
KMast14 is on a distinguished road
I've been looking for a new bearing, and I can't find one anywhere. Any suggestions?
Old August 17th, 2007, 01:27 PM   #11
HMUSN's Avatar
iTrader: 9 reviews
Try ford.. they are normally under $30.00
Threads Similar to: T/O Bearing....
Bearing Kit scxc15 V6 Mustangs 3 October 16th, 2007 08:07 AM
Throw Out Bearing KMast14 V6 Mustangs 17 August 6th, 2007 07:43 PM
Bearing Kit Kennhyy3 V6 Mustangs 9 July 20th, 2007 07:35 PM
throw out bearing already???? 40thmustanggt 99-04 12 July 9th, 2007 10:26 PM
bad pinion bearing dshep Modular Mustangs 1 June 27th, 2007 04:17 AM
