Manual Transmission Fluid
LinkBack (1) Thread Tools
Old August 27th, 2007, 01:14 AM   1 links from elsewhere to this Post. Click to view. #1
lwhitetrash88l's Avatar
2004 Mustang
lwhitetrash88l is on a distinguished road
Send a message via AIM to lwhitetrash88l
okay okay, stupid question but...where in the HELL do i refill the tranny fluid that drained out of it when i dropped the driveshaft? i cant seem to find it and i cant find the freaking haynes book either...anyone feel like filling me in?
Old August 27th, 2007, 01:27 AM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
should be on the side of the tranny you'll need a syphon pump
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 27th, 2007, 02:16 AM   #3
2004 Mustang
where can i get one of those and how much does it cost?
Old August 27th, 2007, 02:25 AM   #4
00 V6 & 09 GT
advaned auto parts
like $5-15 depending which you get
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 27th, 2007, 08:58 AM   #5
2004 Mustang
thanks man
Old August 27th, 2007, 12:56 PM   #6
00 V6 & 09 GT
no prob. if your still having a problem chekc out a haynes manual...that'll show you everything you need for that kinda project your doing
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 27th, 2007, 10:31 PM   #7
2004 Mustang
yeah i have a haynes manual but i freaking cant find it...this sucks lol
Old August 28th, 2007, 12:50 PM   #8
stephen has a spectacular aura aboutstephen has a spectacular aura about
You can buy a gear oil pump from an auto parts store. You will need to find and remove the fill plug which shoud be on the side of the transmission and add fluid till it overflows. Be sure to check what type of oil it takes. They used to use hypoid oil but many now use special manual transmission fluid or automatic transmission fluid with a friction modifier.
Old August 28th, 2007, 01:37 PM   #9
02ponypackage's Avatar
02ponypackage is on a distinguished road
add fluid till it over flows ? why is that...i heard u shouldnt be doing that
just a V6 with a bad belt slip under the hood
Old August 28th, 2007, 01:50 PM   #10
I would say check what the shop manual or owners handbook says.
The car should be level when you add oil and usually they want the level at close to where the fill plug is or slightly below. So check the manual.
If you do get it overfilled it might leak fluid at the rear seal or input shaft seal, so yes you waqnt to avoid overfilling.
Old August 28th, 2007, 02:43 PM   #11
tjames's Avatar
04 Mustang
tjames will become famous soon enough
well i know for a fact that my tranny on my 04 uses auto tranny fluid even though i have a 5 speed.
Sponsor: Chips V6 Specialties
2004 238C.I. 3.9L V6 Mustang
Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit
Originally Posted by xSxTxAxNxGx View Post
dude you're like santa claus lol
Old August 28th, 2007, 02:45 PM   #12
00 V6 & 09 GT
maybe for your rear diff...
i dont think thats how it works for the tranny
[SIGPIC][/SIGPIC]
Acmillr loves me
Old August 28th, 2007, 03:32 PM   #13
Yes that's how the rear axle is filled.
For the manual trans I would strongly recommend checking the owners handbook for type of fluid and the proper level. I know some Ford products have used automatic trans fluid with a friction modifier and some cars use a fluid specifically designed for the manual trans.
Old August 28th, 2007, 03:52 PM   #14
Take a look at the following for the procedure and check with Ford for the type of oil. I would guess the synthetic manual trans fluid would be OK.
http://focus.noegruts.com/trannyoil/trannyoil.htm
Old August 29th, 2007, 11:06 AM   #15
With respect to the type of fluid for the manual trans, the shop manual for a 99 V6 says to use Mercon ATF. I would think the fluid mentioned in the preceeding post would be better.
Old August 29th, 2007, 11:47 AM   #16
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
filling it till it over flows is the stupidest idea... i had a lawn mower where my brother did that with oil... cost me $20 to fix everything that was broken...
add the proper amount needed ... they have a full line on the dip stick for a reason
Old August 29th, 2007, 10:40 PM   #17
Just to clarify this point. This is a manual transmission and I don't believe it has a dipstick. I would check the shop manual, but usually you fill it to just below the fill plug.
Old August 29th, 2007, 10:55 PM   #18
HMUSN's Avatar
iTrader: 9 reviews
^it doesn't have a dip stick . your correct.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/32616-manual-transmission-fluid.html
Manual Transmission Fluid This thread Refback November 7th, 2010 12:31 PM
Threads Similar to: Manual Transmission Fluid
Manual transmission fluid change Saleen0101 99-04 27 August 10th, 2011 09:29 PM
What Transmission Fluid? Murderjetz General Tech 8 November 11th, 2007 12:39 AM
Royal Purple Synchromax Manual Transmission Fluid 006leenstang00 V6 Mustangs 7 May 28th, 2007 03:05 AM
transmission fluid firefly1241 5.0 Mustangs 10 April 1st, 2007 05:33 PM
transmission fluid 1990CA50 5.0 Mustangs 1 December 12th, 2006 02:48 PM
