Rattling
I Have a 98 mustang v6 and whenever i start it up it has this weird rattling noise. Not just at a cold startup but at every startup, and one place said it was my rear main bearing seal and another place said it was my starter. Not sure what the problem is but it started after i went to ohio, when i got back from ohio i was up to 6000 miles since my last oil change and i usually do it every 3000.
48.47@ 12.58
umm ok first... go change your oil
your car hates you right now. secondly... where is the noise coming from?
oil has been changed, it was changed right after i got back. and it sounds like its coming from the rear of the engine around the transmission
#4 | |
48.47@ 12.58
sounds like a heat shield on you catalitic converter.
go check under the car and see it that's the problem.
its a auto. dont have the car yet about to go pick it up once my ride gets here. after that ill put it up on ramps and check that out.
#7 | |
whenever i put it in drive it rattles louder for a second or 2 then when im driving at higher rmps in second and third theres a humming noise and vibration in the gas pedal
48.47@ 12.58
yea that sounds like it.
the heat sheilds dont seem to be rattling at all, they arent loose or anything. im not leaking anything either so i highly doubt its my rear main bearing seal.
#11 | |
autos have "flexplates" as the correct word
#13 | |
The George Forman of Keepers
you might have Buckeyes stuck in your engine.
I had the same simptoms in my Berretta years ago. I sold the damn thing the way it was. The fix sounds expensive. Good luck... |
Threads Similar to: Rattling
| exhaust rattling | emgjsdk1 | General Tech | 2 | October 23rd, 2007 11:10 AM |
| Trunk rattling with sub? | twok3gt | 99-04 | 18 | October 14th, 2007 08:37 PM |
| Rattling noise | SoonerBorn | V6 Mustangs | 15 | September 7th, 2007 09:55 AM |
| Rattling | Lefty | Audio/Video | 6 | July 5th, 2007 02:38 PM |
| Rattling... | D-Brow | V6 Mustangs | 2 | January 26th, 2007 11:12 PM |
