strong vibration from steering wheel - Page 2
Old August 31st, 2007, 06:44 PM   #21
sbland26's Avatar
2004 Mustang Mach 1
sbland26 is on a distinguished road
Send a message via AIM to sbland26
Originally Posted by ja002gl
needless to say, my shaft still vibrates and my wife loves it.
Old March 22nd, 2011, 04:08 PM   #22
CrappyV6 is an unknown quantity at this point
It's the control arm bolts that hold the front sway bar on. It's right there where it connects to that puny little shock (not the main strut). Once it get's really loose, not only will the vibrating move to a higher speed, like 72-75 M.P.H. but you'll start hearing all the crap rattle because as the bolts become more loose over time, so do all the parts associated with the tightness of the bolts. Here's the problem, you think you are tightning this part but if you could see inside the deep socket you are using, everything is turning, throwing the torque specs out the window, rendering the part useless...... unless you get lucky enough to get this piston back to where it's supposed to be......... That magic spot where you can finally tighten everything and not get that annoying rattle from every part associated with the front sway bar. Good luck and thanks for buying a Ford.
Old March 22nd, 2011, 07:33 PM   #23
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
go back to clubcivic.com kid
238rwhp/263rwtq
Drew's Build Thread
Threads Similar to: strong vibration from steering wheel
steering wheel brokebp417 5.0 Mustangs 8 November 10th, 2008 09:34 AM
steering wheel mustang1072 V6 Mustangs 22 July 26th, 2007 08:35 PM
Steering wheel help... TurboLX General Tech 0 June 10th, 2007 04:19 PM
Steering wheel Nick_Rapitis V6 Mustangs 6 May 25th, 2007 04:39 PM
05-06 steering wheel for 98 markanthonymuns V6 Mustangs 2 February 21st, 2007 02:04 PM
