Rumors (Limited Slip)
I have a 2003 mustang and i have limited slip rear differential and i heard if you put it in reverse than first that it will hook and i would leave to tire marks instead of a peg leg u tried this but i was on gravel so i am not quite sure if it always works but it did that time will it always work
#2 | |
¡ʇsnq ɹo uʍop ǝpısdn
Re: Rumors (Limited Slip)
and no this doesn't work... it just skins your tires faster
so it doesnt always work i will still leave peg legs i also heard if you turn your wheel a little it works i dont care about these tires they are
Goodyear Eagle LS and they suck i was just wanting to give them a farewell |
1999 Ford Mustang V6
14.79 @ 92.15
no the inside tire will spin faster, so if you quickly change direction, both will spin. you have an open differential and only spin the inside tire in turns, and in straight lines, you spin the right one
get a Posi, i did and it was worth it, i laied a 75 ft t wheel patch of rubber a few weeks back and when it shifter to 2nd it left a 10 ft patch of rubber lol it was great
well were can i get a posi you mean just a gt rear end
11.21@123 -150 shot
![]() iTrader: 1 reviews
Ford trac lok will install in your rear housing without having to upgrade everything. I believe the 6ers have a 7.5".
yes this does work...ive done it before...it just has to be done perfect...its not easy to do and u wont get it everytime...u can also go up a slight hill in 1st and roll back down a bit then release the clutch then gas it and they both will spin in place....
just a V6 with a bad belt slip under the hood |
beware one wheel peels will shear your differential pins locking bolt and you will be fucked 3 ways till sunday if the spider gears seizes on the pin. i had to chop my stock diff out of the stang.
http://www.moddedmustangs.com/forums...=393423#393423
their is a bit of gear info and a bit of pricing info ... expect to pay $400 ish on install TOPS!
400 ? damn thats pricey...i found a place for 250 can do the tlok and gears
... shopping is so important when it comes to install ... im just saying that because that was an average that i saw when looking around a few weeks ago...
i got from $300 - $700 it all depends on how good you are at shopping around
well if u live in central florida some what or not far from Debary where VMP is...theres a gear shop down the street from then that does T loks and gears...for cheap
14.79 @ 92.15
dont pay more than 300 for install. i got it done for 200
#15 | |
#16 | ||
Threads Similar to: Rumors (Limited Slip)
| Posi Or Limited slip | 05MUSTANG4.0 | V6 Mustangs | 6 | June 18th, 2007 10:49 AM |
| limited slip? | cpork | V6 Mustangs | 7 | May 9th, 2007 02:36 PM |
| limited slip differential | burlingtonNC98GT | 96-98 | 6 | April 17th, 2007 12:54 PM |
| Limited slip posi? | JSmith9136 | V6 Mustangs | 4 | February 2nd, 2007 07:20 AM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 04:59 PM |
