Opportunity Knocks? I blew my head gasket.
Old September 5th, 2007, 11:51 PM   #1
Lankolf's Avatar
97' 3.8 and 65' GT 289
Lankolf is on a distinguished road
Send a message via MSN to Lankolf
Well, I blew my head gasket. I wasn't doing anything stupid, just going 80 in a 75 zone, down I-25 in fifth gear. I guess I ran out of coolant, or something, but my head gasket blew. I didn't really hear it boiling over or anything, my radio was on, and the window was down. Anyway, I was wondering, what do you guys think, did I warp the heads when I blew the gasket? Obviously I need to take the heads off and check it out, but before I start spending time and money, I wanted a second opinion. If I warped the heads, should I invest in new hi-po heads, get stock heads, or replace the engine, or not waste my money? I'm more knowledgeable around drive-train, and I've never really done much with the engine. (here's my chance!) They say knowledge is your replacement for money. Is it hard to take the heads off and put them back on with all the sensors and what-not, or is it less then rocket science? For my first time doing it, should I hire somebody to help me, or should I just read up and dive in? The engines does have 128k on it, maybe I should just jump into a reliable 3.8 with 40K or less? I'd love to hear some opinions, thanks.
Your love of the Halfling's leaf has clearly Slowed your mind.
-Saruman, Fellowship of the Ring
I am the Lizard King, I can do anything.
-Jim Morrison, The Doors
Old September 6th, 2007, 12:23 AM   #2
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
If you can do the install yourself then its not really that expensive to do. it does however take a good bit of work and basically everything comes off the top end of the engine. a/c, alt., brackets, intake, everything. i could get you a detailed sheet on how to do the head gasket replacement if you like
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old September 6th, 2007, 01:02 AM   #3
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
how big is your wallet??
you got some options... replace the head gasket and have the head milled down a hundreth or so...
get new performance heads from ssms ... aka power pack...
get a new engine from ssms or delk or where ever... morana ... something like that
i personally would look at a power pack but thats only cause it is a while your their kinda thing... if you don't have much money though try working with what you got... delk and morana might have head packages but im not sure i have never checked
Old September 6th, 2007, 03:12 AM   #4
yea it depends on your budget. if you can afford to upgrade then do so.
If not then just replace the gaskets and be done with it. Since you just blew the gasket and i assume havent been driving on it for very long at all with high temps, theres no reason why your heads would be warped.
Old September 6th, 2007, 11:13 AM   #5
stephen has a spectacular aura aboutstephen has a spectacular aura about
It's a big job but possible to do at home.
I would get the factory shop manual for the car ( from Helm publications) since it has detailed pictures of each step. Or you can use a digital camera to document it.
A few tips.
You will need an assortment of torque wrenches to reassemble it. I had to buy a small one to torque the manifold bolts.
The head bolts require a major breaker bar to get loose as well as to angle torque them.
The AC doesn't need to be discharged, just tie the compressor aside.
I would at least have a machine shop check out the heads and resurface them.
Old September 7th, 2007, 10:48 PM   #6
Lankolf's Avatar
Thanks you all, I think I have it figured out.
Old September 19th, 2007, 09:49 PM   #7
Lankolf's Avatar
Well, I got the whole top end of the car off, it was a blast to do. I learned a lot, which I really enjoyed, and now the heads are off. I blew the one on the passenger side, as I had suspected, and I figured out what happened, the freeze plug popped out from high steam pressure, from overheating. (I'm guessing the thermostat, but I'll look into that more.) My heads look fine, but I'll have to take them to a machine shop before I write a gospel about that. However my valve are definitely warped. My cousin told me he would help me rebuild the heads, and bore them out ourselves, rather then putting new ones on. He said they were fine, and we could just tune them a bit for more HP. I found out my intake manifold was cracked in the endeavor as well. So far that's the word. We plan on upgrading the manifold as well, so I guess I could get some pretty nice horse power gains from all this, and even better, some good know how.
Plans for the future; More effective camshaft, forged pistons, forced induction(Not sure if I'll go with NOS, turbo, or Super Charger yet.) CAI, Dual exhaust.
How does all that sound? I know HP doesn't just add up because you put "hi-po" crap on there, parts work together, so with that in mind, modding the heads first and foremost, does this all sound like a good direction?
Old September 19th, 2007, 09:58 PM   #8
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
good luck man
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old September 19th, 2007, 09:58 PM   #9
97fordsixer's Avatar
97 single port w/bolt ons
n/a
97fordsixer will become famous soon enough
definitely go with some exhaust, i ran flowmaster 40's on my sixer and sounds tough.
bolt ons for now..... split port swap very soon....
Old September 19th, 2007, 10:17 PM   #10
Lankolf's Avatar
Yea, sound is good, but when it comes time to put your money where your mouth is, I want my pony to preform too. No doubt though, dual exhaust isn't going to do anything but HP gains.
Old September 19th, 2007, 10:56 PM   #11
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
what i would do is take your heads and manifolds to a machine shop and get them ported and polished..and get your valves grind out
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra
Old September 19th, 2007, 11:13 PM   #12
Lankolf's Avatar
OK, if that gives me the most HP gains those heads have to offer.
Old September 20th, 2007, 01:49 AM   #13
Onemanzu's Avatar
thats what super six motor sports does they enlarge the valve body and what not...
also i would look at shaving off a hundreth or two on the bottom of the head to kick the compression up... unless you plan on boosting it... if your going to run N2O then don't bump the compression
Old September 20th, 2007, 08:02 AM   #14
Hourofpain's Avatar
how much are you looking to spend?
1996 Cobra
To be sold...
Old September 23rd, 2007, 12:22 PM   #15
Lankolf's Avatar
I could spend a bit. Money isn't a serious problem, I'll make money.
I so I checked out the heads, they are pretty straight, but it wouldn't hurt to shave em a bit. That is what my initial plan was, that is until my buddy called me yesterday.
So this engine has 128k on it, not too bad, but it's not brand new or anything. Obviously I have to smoke the tires and spin around in the rain, or I would rather just not have the car at all. Well, that abuses the engine plenty.
To keep on topic. My buddy called me and told me he had this 4.6 police interceptor that he'd sell me for a hundred bucks if I really wanted it. At first I said no way man, that would take more work and money then just fixing my car up. Then we thought that maybe it would be quicker, maybe even cheaper to convert the engine to a carb.
Here's what I have to work with, maybe I'm misled in my information, thus this post. I have a T5 Tranny, so I think it'll bolt up to the engine, though I'm sure I'll need a new clutch. I can buy a 4.6 carb manifold, and I have a few carbs around that I could use off of a 351w. (My family owns a salvage yard) I have a 351w radiator right here in my room that I may be able to use if it's compatible. So basicly if I eliminate the computer, all I have to do is bolt it to the exhaust, drivetrain, throttle, distributer(I'm sure I'll need a new one) and go, right? It's a hundred dollars for this engine, and I'm thinking I could invest less then $400 dollars in parts if I use what I already have, and rely on my family's salvage yard. That might be cheaper then getting my heads machined, new valves, and new gasket set, and I can still sell my 3.8 since I won't need it. What do you guys think of that idea? If it's a bad idea, just tell me and I'll fix my 3.8.
Edit: I didn't forget about suspension, but my thinking is, if the engine weighs less then 300 pounds then my current, then what would be the difference from having a few fat people in the car? I can always change the suspension out later too when I get it running again.
Old September 23rd, 2007, 01:32 PM   #16
Hourofpain's Avatar
shit
a carbed 4.6 go for it.
but dont forget the engine mounts and tranny mounts. and then the new fuel pump
wiring harness.. actaully nvm
1996 Cobra
To be sold...
Old September 23rd, 2007, 02:07 PM   #17
Lankolf's Avatar
I don't get it, are you being factious? I wouldn't need the wiring harness if I did carb, I though...
Old September 23rd, 2007, 03:11 PM   #18
Hourofpain's Avatar
thats why i said nvm on the harness
1996 Cobra
To be sold...
Old September 23rd, 2007, 03:12 PM   #19
Hourofpain's Avatar
oh youll need to chgange out your rear end.
that 7 wont handle it
move up to an 8
1996 Cobra
To be sold...
Old September 23rd, 2007, 03:24 PM   #20
tjames's Avatar
04 Mustang
tjames will become famous soon enough
8.8 in case you dont know what he is talkin about. the 8.8 comes stock in the GTs
Sponsor: Chips V6 Specialties
2004 238C.I. 3.9L V6 Mustang
Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit
Originally Posted by xSxTxAxNxGx View Post
dude you're like santa claus lol
Threads Similar to: Opportunity Knocks? I blew my head gasket.
blown head gasket 5.0pwr 96-98 2 September 17th, 2007 11:57 PM
Head gasket nasty92LX 5.0 Mustangs 9 September 13th, 2007 04:25 PM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 10:48 PM
99 3.8 L Head Gasket? Mike s V6 Mustangs 11 November 13th, 2006 03:51 PM
head gasket cali 5.0 5.0 Mustangs 3 June 20th, 2006 03:33 PM
