My Stallion is Bigger!
TSB Listing and recalls
Click on the appropriate link
2003 http://www.moddedmustangs.com/forums...2994.html#2994 2002 http://www.moddedmustangs.com/forums...2995.html#2995 2001 http://www.moddedmustangs.com/forums...2996.html#2996 2000 http://www.moddedmustangs.com/forums...2997.html#2997 1999 http://www.moddedmustangs.com/forums...2998.html#2998 1998 http://www.moddedmustangs.com/forums...3008.html#3008 1997 http://www.moddedmustangs.com/forums...3009.html#3009 1996 http://www.moddedmustangs.com/forums...3010.html#3010 1995 http://www.moddedmustangs.com/forums...3022.html#3022 1994 http://www.moddedmustangs.com/forums...3023.html#3023
Bulletins for 2003 Ford Mustang V6-232 3.8L VIN 4 SFI
Service Bulletins TSB Number Issue Date TSB Title 03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound 02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info 02-23-3 NOV 02 Fuel System - Fuel Pressure Relief Valve Discontinued 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
Bulletins for 2002 Ford Mustang V6-232 3.8L VIN 4 SFI
Service Bulletins TSB Number Issue Date TSB Title 03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound 02-23-7 NOV 02 Cooling System - Premium Gold Coolant Service Info 02-23-4 NOV 02 Engine Controls - DTC P1635 Set After PCM/IC Replacement 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-17-8 SEP 02 Interior - 'A' Pillar Area Wind Noise 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-9-8 MAY 02 Convertible Top Boot - Poor Fit 02-5-4 MAR 02 Accessory Drive Belt - Slips Off Pulley When Wet 02-5-6 MAR 02 Sheet Metal (Primed) - Preparation Procedure 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure
Bulletins for 2001 Ford Mustang V6-232 3.8L VIN 4 SFI
Safety Recalls TSB Number Issue Date TSB Title 00S37 OCT 00 Recall - Park Brake Control Modification General Recalls TSB Number Issue Date TSB Title 01T04 SEP 01 Campaign - IMRC Set Screw Inspection/Repair 00L12 JAN 01 Campaign - Warranty Guide Supplement Service Bulletins TSB Number Issue Date TSB Title 03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound 02-23-4 NOV 02 Engine Controls - DTC P1635 Set After PCM/IC Replacement 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-17-8 SEP 02 Interior - 'A' Pillar Area Wind Noise 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-9-8 MAY 02 Convertible Top Boot - Poor Fit 02-5-4 MAR 02 Accessory Drive Belt - Slips Off Pulley When Wet 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-13-7 JUL 01 A/T - 4R70W Clunk Noise on 2nd to 1st Gear Downshift 01-10-8 MAY 01 Driveline - Whining Noise On Coastdown 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set 01-6-2 APR 01 PATS System - Diagnostic Service Tips 01-5-8 MAR 01 A/T - 4R70W Ticking Noise In 1ST Gear 01-4-8 MAR 01 Engine Oil Pump - LIS Service 01-3-1 FEB 01 PCM - MIL ON, DTC P0442 Set 01-2-5 FEB 01 Seat Belts - Warning System Operation 00-26-6 DEC 00 Engine Oil Pump - Liquid Injection Seal Service 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-16-1 AUG 00 A/T - ``Prior To Repair'' Tag Procedure Notice
Bulletins for 2000 Ford Mustang V6-232 3.8L VIN 4 SFI
Safety Recalls TSB Number Issue Date TSB Title 00S37 OCT 00 Recall - Park Brake Control Modification 99S26 OCT 99 Recall - Safety Belt Retractor Inspection/Replacement Service Bulletins TSB Number Issue Date TSB Title 03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound 02-23-4 NOV 02 Engine Controls - DTC P1635 Set After PCM/IC Replacement 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-13-7 JUL 01 A/T - 4R70W Clunk Noise on 2nd to 1st Gear Downshift 01-10-8 MAY 01 Driveline - Whining Noise On Coastdown 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set 01-6-2 APR 01 PATS System - Diagnostic Service Tips 01-5-8 MAR 01 A/T - 4R70W Ticking Noise In 1ST Gear 01-2-5 FEB 01 Seat Belts - Warning System Operation 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-14-2 JUL 00 Speedometer Defective,, 4X4 Lamp ON, DTCs P1635/P1639 00-9-1 MAY 00 A/T Cooler - Fluid Leaks at Radiator 00-9-6 MAY 00 Windshield Wipers - Operate While Switch is OFF 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-24-2 NOV 99 Locks - Lock Service Packages Available 99-23-4 NOV 99 EVAP - DTC's P0442/P0455/MIL ON/No Driveability Concerns 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-14-12 JUL 99 A/T - 4R70W Green Service Tag Service procedure
Bulletins for 1999 Ford Mustang V6-232 3.8L VIN 4 SFI
Safety Recalls TSB Number Issue Date TSB Title 00S37 OCT 00 Recall - Park Brake Control Modification 99S26 OCT 99 Recall - Safety Belt Retractor Inspection/Replacement 99S09 MAR 99 Recall - Speed Control Cable Replacement Service Bulletins TSB Number Issue Date TSB Title 03-1-5 JAN 03 Interior - Passenger Seat Squeaking Sound 02-23-4 NOV 02 Engine Controls - DTC P1635 Set After PCM/IC Replacement 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-17-4 SEP 01 Hood Scoop - Loose or Detached 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-13-7 JUL 01 A/T - 4R70W Clunk Noise on 2nd to 1st Gear Downshift 01-10-8 MAY 01 Driveline - Whining Noise On Coastdown 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 01-6-2 APR 01 PATS System - Diagnostic Service Tips 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-14-2 JUL 00 Speedometer Defective,, 4X4 Lamp ON, DTCs P1635/P1639 00-9-1 MAY 00 A/T Cooler - Fluid Leaks at Radiator 00-9-6 MAY 00 Windshield Wipers - Operate While Switch is OFF 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-24-2 NOV 99 Locks - Lock Service Packages Available 99-23-4 NOV 99 EVAP - DTC's P0442/P0455/MIL ON/No Driveability Concerns 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-6 NOV 99 Driver's Footwell Area - Popping/Oil Canning Noise 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-21-8 OCT 99 Left Hand Rear Quarter Area - Creaking Noise 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-7 SEP 99 A/T - 4R70W TCIL/MIL ON/Trouble Codes Stored 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-18-5 SEP 99 A/T - 4R70W TCIL ON/Code P0782/Delayed/No 2-3 Upshift 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-15-3 JUL 99 Cup Holder - Not Deep Enough to Hold Large Cups 99-14-7 JUL 99 PCM - Calibration Information 99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure 99-12-10 JUN 99 Paint - Rough Texture 99-10-1 JUN 99 Body - Road Noise/Dust/Water in Luggage Compartment 99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-5-3 MAR 99 A/T - Cold Fluid Level Checking 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 99-2-3 FEB 99 Windshield - Water Leaks 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-9 DEC 98 Interior Trim - Vinyl Surface Repair Tips 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-10 NOV 98 Engine - Lean Driveability Symptoms
Bulletins for 1998 Ford Mustang V6-232 3.8L VIN 4 SFI
Safety Recalls TSB Number Issue Date TSB Title 00S37 OCT 00 Recall - Park Brake Control Modification 99S09 MAR 99 Recall - Speed Control Cable Replacement Service Bulletins TSB Number Issue Date TSB Title 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-11-7 JUN 02 A/C System - Musty/Mildew Odors 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-4-5 FEB 02 Battery - Charging Tips and Guidelines 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 01-6-2 APR 01 PATS System - Diagnostic Service Tips 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-9-1 MAY 00 A/T Cooler - Fluid Leaks at Radiator 00-4-2 FEB 00 Engine Mount/Frame - Vibration/Shake 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-24-2 NOV 99 Locks - Lock Service Packages Available 99-23-4 NOV 99 EVAP - DTC's P0442/P0455/MIL ON/No Driveability Concerns 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-20-7 OCT 99 Engine - Coolant Loss/Oil Contamination 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-18-5 SEP 99 A/T - 4R70W TCIL ON/Code P0782/Delayed/No 2-3 Upshift 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure 99-12-10 JUN 99 Paint - Rough Texture 99-10-1 JUN 99 Body - Road Noise/Dust/Water in Luggage Compartment 99-9-6 MAY 99 A/T - 4R70W (Remanufactured) Delayed or No 2-3 Upshift 99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-5-3 MAR 99 A/T - Cold Fluid Level Checking 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 99-2-3 FEB 99 Windshield - Water Leaks 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-3 DEC 98 Front Window - Travels Out Of The Glass Run 98-25-9 DEC 98 Interior Trim - Vinyl Surface Repair Tips 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-12 NOV 98 A/T - Multiple DTC's Stored Diagnosis 98-23-10 NOV 98 Engine - Lean Driveability Symptoms 98-22-2 NOV 98 Clutch - Vibration/Noise Felt In Clutch Pedal 98-20-3 OCT 98 Body - Structural Adhesive Recommendations 98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise 98-18-2 SEP 98 Paint - Materials For After Warranty/Warranty Repairs 98-18-15 SEP 98 Safety Certification Label - Cleaning Precautions 98-17-18 SEP 98 Rocker Panel Mouldings - Loose 98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips 98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement 98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing 98-7-4 APR 98 Engine - New Gasket Sealer 98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment 98-4-12 MAR 98 A/T - 4R70W Orange Service Tag Service Procedure 98-4-4 MAR 98 Paint - Anti Chip Stone Abrasion Undercoat Service Tip 98-5-2 MAR 98 Tires - Company Customer Assistance Telephone Numbers 98-3-3 FEB 98 Paint - Surface Defect Removal Without Repainting 97-25A DEC 97 EVAP System - Diagnosis & Testing 97-17-18 AUG 97 A/T - 4R70W Orange Tag Diagnostic Procedure
Bulletins for 1997 Ford Mustang V6-232 3.8L VIN 4 SFI
Safety Recalls TSB Number Issue Date TSB Title 01S28 SEP 01 Recall - Air Bag Module Inspection/Replacement 00S37 OCT 00 Recall - Park Brake Control Modification General Recalls TSB Number Issue Date TSB Title 00B43 MAY 00 Campaign - Cooling Fan Clip Replacement 99B29 DEC 99 Campaign - Engine Front Cover Gasket Replacement 97B17 FEB 98 Campaign - Fuel Gauge/Sender Assembly Service Bulletins TSB Number Issue Date TSB Title 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-11-7 JUN 02 A/C System - Musty/Mildew Odors 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-20-5 OCT 01 Driveability - Vacuum Leak Detection 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-8 APR 01 EVAP System - MIL ON Multiple DTC's Set 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 01-6-2 APR 01 PATS System - Diagnostic Service Tips 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-9-1 MAY 00 A/T Cooler - Fluid Leaks at Radiator 00-4-2 FEB 00 Engine Mount/Frame - Vibration/Shake 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-24-2 NOV 99 Locks - Lock Service Packages Available 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-20-7 OCT 99 Engine - Coolant Loss/Oil Contamination 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-18-5 SEP 99 A/T - 4R70W TCIL ON/Code P0782/Delayed/No 2-3 Upshift 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure 99-12-10 JUN 99 Paint - Rough Texture 99-10-1 JUN 99 Body - Road Noise/Dust/Water in Luggage Compartment 99-9-6 MAY 99 A/T - 4R70W (Remanufactured) Delayed or No 2-3 Upshift 99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-5-3 MAR 99 A/T - Cold Fluid Level Checking 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 99-2-3 FEB 99 Windshield - Water Leaks 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-3 DEC 98 Front Window - Travels Out Of The Glass Run 98-25-9 DEC 98 Interior Trim - Vinyl Surface Repair Tips 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-10 NOV 98 Engine - Lean Driveability Symptoms 98-22-2 NOV 98 Clutch - Vibration/Noise Felt In Clutch Pedal 98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise 98-18-2 SEP 98 Paint - Materials For After Warranty/Warranty Repairs 98-17-18 SEP 98 Rocker Panel Mouldings - Loose 98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips 98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement 98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing 98-8-7 APR 98 A/T - AODE/4R70W Shudder/Vibration Over 35 mph 98-7-4 APR 98 Engine - New Gasket Sealer 98-5A-11 MAR 98 Brakes - Elimination Of Sanding Rotors And Drums 98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment 98-5A-4 MAR 98 Lug Nuts - Proper Installation/Torqueing Procedure 98-5-2 MAR 98 Tires - Company Customer Assistance Telephone Numbers 98-2-7 FEB 98 Air Conditioning - Musty/Mildew Type Odors 97-25-5 DEC 97 Blower Motor - Chirping/Squeaking 97-24-1 NOV 97 Convertible Top - Leaks In Rain And/Or Car Wash 97-24-13 NOV 97 Remote Keyless Entry - Diagnostic Service Tips 97-22-1 OCT 97 EGR DPFE Sensor - Voltage Range Revision 97-19-4 SEP 97 Brake and Rotor - Service Tips 97-19-11 SEP 97 Heater Core - On Car Pressure Test For Warranty Claim 97-17-2 AUG 97 Rear View Mirror - Reattachment 97-17-1 AUG 97 Sheet Molding Composite - Body Repair 97-11-11 MAY 97 A/T - AODE/4R70W Erratic/Prolonged 1-2 Shift 97-15-5 MAY 97 A/C - Refrigerant Oil Refill Capacity 97-10-5 MAY 97 A/C - Insufficient Cooling/ Compressor Failure 97-10-4 MAY 97 Engine Cooling Fan Module - Service Information 97-9-8 APR 97 PCM - Reprogramming Tips 97-9-1 APR 97 Rapgard Paint Protection - Service Tip 9787 APR 97 A/C Clutch Cycling Pressure Switch - Service Tip 9735 FEB 97 A/C - R134a Tracer Dye and Three O Ring Spring Couplers 96268 DEC 96 Blower Motor - Intermittant or Inoperative 962612 DEC 96 Torque Converter - Cleaning and Replacement Guidelines 96253 DEC 96 Center Console - Gap Hider Availability 96249 NOV 96 A/T Torque Converter - Leak Test Procedure 96246 NOV 96 Electrical Diode - Identification and Replacement 96225 OCT 96 Mass Air Flow Sensor - Assembly Replacement 96221 OCT 96 Windshield/Interior Glass - Fog/Film 96208 SEP 96 A/C - New O Ring Applications 96207 SEP 96 A/C O Ring - Availability and Applications 96201 SEP 96 Paint - Codes and Colors/Cross Reference 96179 AUG 96 PCM - MIL ON/DTCs P0300 through P0308 Stored
Bulletins for 1996 Ford Mustang V6-232 3.8L
Safety Recalls TSB Number Issue Date TSB Title 01S28 SEP 01 Recall - Air Bag Module Inspection/Replacement 00S37 OCT 00 Recall - Park Brake Control Modification 97S88 NOV 97 Recall - Hood Separation Inspection/Repair General Recalls TSB Number Issue Date TSB Title 99B29 DEC 99 Campaign - Engine Front Cover Gasket Replacement Service Bulletins TSB Number Issue Date TSB Title 02-22-1 NOV 02 Engine Controls - Engine Surge/Rolling Idle/DTC's Set 02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-11-7 JUN 02 A/C System - Musty/Mildew Odors 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-23-5 NOV 01 M/T - T45 Stuck In Reverse/Pops Out Of Reverse 01-21-6 OCT 01 Hood Lamp Switch - Revised 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 01-6-2 APR 01 PATS System - Diagnostic Service Tips 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-4-2 FEB 00 Engine Mount/Frame - Vibration/Shake 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-24-2 NOV 99 Locks - Lock Service Packages Available 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-20-7 OCT 99 Engine - Coolant Loss/Oil Contamination 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure 99-12-10 JUN 99 Paint - Rough Texture 99-9-6 MAY 99 A/T - 4R70W (Remanufactured) Delayed or No 2-3 Upshift 99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 99-2-3 FEB 99 Windshield - Water Leaks 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-3 DEC 98 Front Window - Travels Out Of The Glass Run 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-10 NOV 98 Engine - Lean Driveability Symptoms 98-22-2 NOV 98 Clutch - Vibration/Noise Felt In Clutch Pedal 98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise 98-17-18 SEP 98 Rocker Panel Mouldings - Loose 98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips 98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement 98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing 98-8-7 APR 98 A/T - AODE/4R70W Shudder/Vibration Over 35 mph 98-7-4 APR 98 Engine - New Gasket Sealer 98-5A-11 MAR 98 Brakes - Elimination Of Sanding Rotors And Drums 98-5A-13 MAR 98 Brakes - New Silicone Compound/Grease 98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment 98-5A-4 MAR 98 Lug Nuts - Proper Installation/Torqueing Procedure 98-5-2 MAR 98 Tires - Company Customer Assistance Telephone Numbers 98-2-7 FEB 98 Air Conditioning - Musty/Mildew Type Odors 97-25-5 DEC 97 Blower Motor - Chirping/Squeaking 97-24-1 NOV 97 Convertible Top - Leaks In Rain And/Or Car Wash 97-24-13 NOV 97 Remote Keyless Entry - Diagnostic Service Tips 97-22-1 OCT 97 EGR DPFE Sensor - Voltage Range Revision 97-19-12 SEP 97 A/C Pressure Switches - Obsolete Parts Return 97-19-4 SEP 97 Brake and Rotor - Service Tips 97-19-11 SEP 97 Heater Core - On Car Pressure Test For Warranty Claim 97-17-2 AUG 97 Rear View Mirror - Reattachment 97-17-1 AUG 97 Sheet Molding Composite - Body Repair 97-11-11 MAY 97 A/T - AODE/4R70W Erratic/Prolonged 1-2 Shift 97-15-5 MAY 97 A/C - Refrigerant Oil Refill Capacity 97-10-5 MAY 97 A/C - Insufficient Cooling/ Compressor Failure 97-10-4 MAY 97 Engine Cooling Fan Module - Service Information 97-9-5 APR 97 Engine - Hard Starting/Long Crank/Stalling 97-9-8 APR 97 PCM - Reprogramming Tips 9786 APR 97 PCM - MIL ON/DTCs From P0300 to P0308 Set 9756 MAR 97 Odometer and Trip Meter - Stick/Clicking Noise 9735 FEB 97 A/C - R134a Tracer Dye and Three O Ring Spring Couplers 96268 DEC 96 Blower Motor - Intermittant or Inoperative 962612 DEC 96 Torque Converter - Cleaning and Replacement Guidelines 96253 DEC 96 Center Console - Gap Hider Availability 96249 NOV 96 A/T Torque Converter - Leak Test Procedure 96246 NOV 96 Electrical Diode - Identification and Replacement 96237 NOV 96 Engine - Front Cover/Water Pump Stud Oil Leak 96225 OCT 96 Mass Air Flow Sensor - Assembly Replacement 96221 OCT 96 Windshield/Interior Glass - Fog/Film 96208 SEP 96 A/C - New O Ring Applications 96207 SEP 96 A/C O Ring - Availability and Applications 96179 AUG 96 PCM - MIL ON/DTCs P0300 through P0308 Stored 96161 JUL 96 Front Suspension - Rattle When Cold 96156 JUL 96 A/C System - Service TSB List 96149 JUL 96 Accessory Drive Belt - Squeal or Hoot Noise 96125 JUN 96 Antitheft System - Diagnostic Procedures/Service Tips 96129 JUN 96 Differential - Chatter On Turns 96111 MAY 96 New Lock Design - Introduction/Service Tip 96107 MAY 96 Fuel - California Reformulated Gasoline 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics 96711 MAR 96 A/T - 4R70W Unique Case With Low/Reverse Spacer 9672 MAR 96 Locks - New Design Lockset Service Tip 9665 MAR 96 A/T - 4R70W # 9 Thrust Bearing Service Tip 9646 FEB 96 Upper Radiator Hose - Coolant Leak 96314 JAN 96 M/T - T5OD Clicking and/or Grinding ATRATB358 JAN 96 A/T - AODE, 4R7OW Valve Body Cross Leaks 95231 NOV 95 Paint - Color Codes/Cross References 95198 SEP 95 Engine - Limited Operating Strategy When Tester Is Used 9244 FEB 92 EEC IV - Self Test Codes and MIL Service Tips ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge ATRATB028 OCT 90 A/T - Engine Vacuum Testing ATRATB9002006 FEB 90 A/T - Choosing the Right ATF ATRATB8930 OCT 89 A/T - Math Part II ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Bulletins for 1995 Ford Mustang V6-232 3.8L
Safety Recalls TSB Number Issue Date TSB Title 01S30 DEC 01 Recall - Cooling Fan Motor Circuit Breaker Installation 01S28 SEP 01 Recall - Air Bag Module Inspection/Replacement 00S37 OCT 00 Recall - Park Brake Control Modification 97S88 NOV 97 Recall - Hood Separation Inspection/Repair 95S17 AUG 95 Recall - Tie Rod End Inspection/Replacement 95S06 MAR 95 Recall - Passenger Side Air Bag Inspection General Recalls TSB Number Issue Date TSB Title 01M09 DEC 01 Campaign - Cooling Fan Motor Warranty Extension 00M10 APR 00 Campaign - Head Gasket Replacement 95B79 JAN 95 Campaign - Keyless Entry System Transmitters Service Bulletins TSB Number Issue Date TSB Title 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-11-7 JUN 02 A/C System - Musty/Mildew Odors 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 01-24-6 DEC 01 Engine - Oil System Priming Procedures 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-21-6 OCT 01 Hood Lamp Switch - Revised 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-11-1 JUN 99 Comprehensive Noise/Vibration/Harshness Procedure 99-8-15 MAY 99 Interior Door Trim Panel - Replacement Tip 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 99-2-3 FEB 99 Windshield - Water Leaks 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-3 DEC 98 Front Window - Travels Out Of The Glass Run 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-10 NOV 98 Engine - Lean Driveability Symptoms 98-22-2 NOV 98 Clutch - Vibration/Noise Felt In Clutch Pedal 98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise 98-17-18 SEP 98 Rocker Panel Mouldings - Loose 98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips 98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement 98-10-8 MAY 98 A/T - AODE/4R70W Revised Forward Clutch Service Tip 98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing 98-8-7 APR 98 A/T - AODE/4R70W Shudder/Vibration Over 35 mph 98-7-4 APR 98 Engine - New Gasket Sealer 98-5A-11 MAR 98 Brakes - Elimination Of Sanding Rotors And Drums 98-5A-13 MAR 98 Brakes - New Silicone Compound/Grease 98-5A-8 MAR 98 Brakes - Rubbing Noise From Underneath Vehicle 98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment 98-5A-4 MAR 98 Lug Nuts - Proper Installation/Torqueing Procedure 98-5A-10 MAR 98 Rear Brakes - Squeaking Noise On First Few Applications 98-5-2 MAR 98 Tires - Company Customer Assistance Telephone Numbers 98-2-7 FEB 98 Air Conditioning - Musty/Mildew Type Odors 97-25-5 DEC 97 Blower Motor - Chirping/Squeaking 97-24-1 NOV 97 Convertible Top - Leaks In Rain And/Or Car Wash 97-24-13 NOV 97 Remote Keyless Entry - Diagnostic Service Tips 97-22-1 OCT 97 EGR DPFE Sensor - Voltage Range Revision 97-19-12 SEP 97 A/C Pressure Switches - Obsolete Parts Return 97-19-13 SEP 97 A/T - AODE Extension Housing Bushing Walkout/Spin 97-19-4 SEP 97 Brake and Rotor - Service Tips 97-19-11 SEP 97 Heater Core - On Car Pressure Test For Warranty Claim 97-17-2 AUG 97 Rear View Mirror - Reattachment 97-17-1 AUG 97 Sheet Molding Composite - Body Repair 97-16-7 AUG 97 A/T - AODE/4R70W Service Tips 97-11-11 MAY 97 A/T - AODE/4R70W Erratic/Prolonged 1-2 Shift 97-15-5 MAY 97 A/C - Refrigerant Oil Refill Capacity 97-10-5 MAY 97 A/C - Insufficient Cooling/ Compressor Failure 97-10-4 MAY 97 Engine Cooling Fan Module - Service Information 97-9-8 APR 97 PCM - Reprogramming Tips 96268 DEC 96 Blower Motor - Intermittant or Inoperative 962612 DEC 96 Torque Converter - Cleaning and Replacement Guidelines 962517 DEC 96 Torque Converter Clutch - Vibration/Shudder 96249 NOV 96 A/T Torque Converter - Leak Test Procedure 96246 NOV 96 Electrical Diode - Identification and Replacement 96225 OCT 96 Mass Air Flow Sensor - Assembly Replacement 96221 OCT 96 Windshield/Interior Glass - Fog/Film 96208 SEP 96 A/C - New O Ring Applications 96207 SEP 96 A/C O Ring - Availability and Applications 96156 JUL 96 A/C System - Service TSB List 96149 JUL 96 Accessory Drive Belt - Squeal or Hoot Noise 96129 JUN 96 Differential - Chatter On Turns 96107 MAY 96 Fuel - California Reformulated Gasoline 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics 9641 FEB 96 Convertible Top -Replacement Service Tip 9611 JAN 96 New Design Tie Rods - Revised Torque Requirements ATRATB327 JAN 96 A/T - AODE Output Shaft Pin Location and Updated Shaft ATRATB358 JAN 96 A/T - AODE, 4R7OW Valve Body Cross Leaks 95243 DEC 95 Engine - Rocker Arm Squeak/Chirp/Knock Noise 95234 NOV 95 A/T - Vibration/Shudder On Light Acceleration 95228 NOV 95 Air Bag Warning Lamp - Incorrect Code 24 Diagnosis 95211 OCT 95 Air Bag Modules - Discolored/Marred Covers 95184 SEP 95 Air Conditioning - Approved Flushing Procedures 95182 SEP 95 Recycled Engine Coolant - Service Tips 95173 AUG 95 Park Brake Handle - Console Interference 951610 AUG 95 A/T - New Rotunda Fluid Changer Service Tip 95144 JUL 95 Ball Joint - Replacement Procedure Tip 95131 JUL 95 A/C Evaporator Core - On Vehicle Leak Test Requirement 95132 JUL 95 Temperature Gauge - Reads Low/Erratic 95121 JUN 95 Windshield - Material Usage Procedure 9593 MAY 95 Radio - Distortion/Poor Reception/Whine/Pop 9584 APR 95 A/T - AODE/4R70W Reusable Pan Gasket/Filter 9562 MAR 95 Brakes - Roughness During Application 9561 MAR 95 Paint - Iron Particle Removal 95512 MAR 95 A/C - Adding Refrigerant Oil Service Tip 95515 MAR 95 A/T - AODE Intermittent Loss of Torque at 3-4 Upshift 95313 FEB 95 A/T - 4R70W/AODE DTC's Set/Shift Concerns 9522 JAN 95 Air Conditioning - O Ring Removal Service Tip 9524 JAN 95 Radiator - New Manufacturing Process 9512 JAN 95 Accelerator Cable - Diagnostic Procedure ATRATB314 JAN 95 A/T - Delayed Engagement, Shift Errors, MLPS Codes ATRATB305 JAN 95 A/T - Shifts To Neutral At Heavy Throttle 94266 DEC 94 A/C - Release of R134a Fluorescent Dye 94262 DEC 94 Air Bag - Diagnostic Trouble Code Retrieval 94265 DEC 94 Headlamps - Removal Procedure Service Tip 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips 94252 DEC 94 Brake Rotor - Machining Equipment/Warranty Information 94239 NOV 94 A/C - Little or No Cooling 94235 NOV 94 Front Brakes - Thumping/Clacking Noise While Braking 94234 NOV 94 Paint - Preparation Procedure And MSDS Information 94226 OCT 94 Temp Control Knob - Does Not Reach Full Cool Position 94206 OCT 94 A/C - Oil Visible At Spring Lock Couplers 94172 AUG 94 Rear View Mirror - Detaches From Windshield 9244 FEB 92 EEC IV - Self Test Codes and MIL Service Tips ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge ATRATB028 OCT 90 A/T - Engine Vacuum Testing ATRATB9002006 FEB 90 A/T - Choosing the Right ATF ATRATB8930 OCT 89 A/T - Math Part II ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Bulletins for 1994 Ford Mustang V6-232 3.8L
Safety Recalls TSB Number Issue Date TSB Title 01S28 SEP 01 Recall - Air Bag Module Inspection/Replacement 00S37 OCT 00 Recall - Park Brake Control Modification 97S88 NOV 97 Recall - Hood Separation Inspection/Repair General Recalls TSB Number Issue Date TSB Title 00M10 APR 00 Campaign - Head Gasket Replacement 95B79 JAN 95 Campaign - Keyless Entry System Transmitter Service Bulletins TSB Number Issue Date TSB Title 02-20-8 OCT 02 A/C System - Diagnosis and Service Tips 02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling 02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers 02-11-7 JUN 02 A/C System - Musty/Mildew Odors 02-11-4 JUN 02 Aluminum Engine - New Cleaners/Service Tips 02-2-3 FEB 02 Engine - Aluminum Block/Head Machining 02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures 02-1-9 JAN 02 Engine Oil - Oil Recommendations/Applications 01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations 01-21-6 OCT 01 Hood Lamp Switch - Revised 01-15-7 AUG 01 A/T - Fluid Application Charts 01-15-6 AUG 01 Heater Core - Repeated Failure 01-10-12 MAY 01 Wire Harness - Terminal Repair Kit 01-9-7 MAY 01 Emissions/Computers/Electronics - Driveability Diagnosis 01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers 00-24-1 NOV 00 Clutch Pedal - Vibration Heard or Felt 00-23-10 NOV 00 A/T - In Line Fluid Filter Kit 00-21-2 OCT 00 Hood - Difficult to Close 00-1-5 JAN 00 A/T - New Transmission Cooler Flusher/Service Tip 99-26-9 DEC 99 Fuel Economy - Customer Expectation vs. Vehicle Usage 99-22-5 NOV 99 Convertible Top Boot - Improper Fit 99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure 99-19-6 SEP 99 A/C - Identification of Non Approved Refrigerants 99-19-4 SEP 99 Brakes - Vibration/Inspection Service Tips 99-15-2 JUL 99 A/T - Transmission Flush and Fill Tool Available 99-8-16 MAY 99 Motor Oil - Viscosity Grade Recommendation 99-4-3 MAR 99 PCM - Reprogramming Out of Vehicle 98-26-2 JAN 99 Fuel - Volatility Related Driveability Concerns 98-25-3 DEC 98 Front Window - Travels Out Of The Glass Run 98-24-6 DEC 98 Electrical - New Terminal Grease Released For Service 98-23-10 NOV 98 Engine - Lean Driveability Symptoms 98-22-2 NOV 98 Clutch - Vibration/Noise Felt In Clutch Pedal 98-20-10 OCT 98 Exhaust System - Buzzing/Rattling Noise 98-17-18 SEP 98 Rocker Panel Mouldings - Loose 98-17-1 SEP 98 Seat Leather - Cleaning Procedure Tips 98-12-5 JUN 98 A/C - Filtering Refrigerant After Compressor Replacement 98-10-8 MAY 98 A/T - AODE/4R70W Revised Forward Clutch Service Tip 98-9-9 MAY 98 Fuel Injectors - Non Warranty Reimbursement Testing 98-8-7 APR 98 A/T - AODE/4R70W Shudder/Vibration Over 35 mph 98-7-4 APR 98 Engine - New Gasket Sealer 98-5A-11 MAR 98 Brakes - Elimination Of Sanding Rotors And Drums 98-5A-13 MAR 98 Brakes - New Silicone Compound/Grease 98-5A-8 MAR 98 Brakes - Rubbing Noise From Underneath Vehicle 98-5A-5 MAR 98 Hub-Mount Brake Rotor Machining Equipment 98-5A-4 MAR 98 Lug Nuts - Proper Installation/Torqueing Procedure 98-5A-10 MAR 98 Rear Brakes - Squeaking Noise On First Few Applications 98-5-2 MAR 98 Tires - Company Customer Assistance Telephone Numbers 98-2-7 FEB 98 Air Conditioning - Musty/Mildew Type Odors 97-25-5 DEC 97 Blower Motor - Chirping/Squeaking 97-24-1 NOV 97 Convertible Top - Leaks In Rain And/Or Car Wash 97-24-13 NOV 97 Remote Keyless Entry - Diagnostic Service Tips 97-22-1 OCT 97 EGR DPFE Sensor - Voltage Range Revision 97-19-12 SEP 97 A/C Pressure Switches - Obsolete Parts Return 97-19-13 SEP 97 A/T - AODE Extension Housing Bushing Walkout/Spin 97-19-4 SEP 97 Brake and Rotor - Service Tips 97-19-11 SEP 97 Heater Core - On Car Pressure Test For Warranty Claim 97-17-7 AUG 97 PCM - MIL ON/Multiple DTC's Set 97-17-2 AUG 97 Rear View Mirror - Reattachment 97-16-7 AUG 97 A/T - AODE/4R70W Service Tips 97-11-11 MAY 97 A/T - AODE/4R70W Erratic/Prolonged 1-2 Shift 97-15-5 MAY 97 A/C - Refrigerant Oil Refill Capacity 97-10-5 MAY 97 A/C - Insufficient Cooling/ Compressor Failure 97-10-4 MAY 97 Engine Cooling Fan Module - Service Information 97-9-8 APR 97 PCM - Reprogramming Tips 96268 DEC 96 Blower Motor - Intermittant or Inoperative 962612 DEC 96 Torque Converter - Cleaning and Replacement Guidelines 962517 DEC 96 Torque Converter Clutch - Vibration/Shudder 96249 NOV 96 A/T Torque Converter - Leak Test Procedure 96246 NOV 96 Electrical Diode - Identification and Replacement 96225 OCT 96 Mass Air Flow Sensor - Assembly Replacement 96221 OCT 96 Windshield/Interior Glass - Fog/Film 96208 SEP 96 A/C - New O Ring Applications 96207 SEP 96 A/C O Ring - Availability and Applications 96156 JUL 96 A/C System - Service TSB List 96149 JUL 96 Accessory Drive Belt - Squeal or Hoot Noise 96129 JUN 96 Differential - Chatter On Turns 96107 MAY 96 Fuel - California Reformulated Gasoline 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics 9641 FEB 96 Convertible Top -Replacement Service Tip 9611 JAN 96 New Design Tie Rods - Revised Torque Requirements ATRATB327 JAN 96 A/T - AODE Output Shaft Pin Location and Updated Shaft ATRATB358 JAN 96 A/T - AODE, 4R7OW Valve Body Cross Leaks ATRATB359 JAN 96 A/T - AXOD, AX4S (AXODE) Revised Forward Sprag Race 95243 DEC 95 Engine - Rocker Arm Squeak/Chirp/Knock Noise 95234 NOV 95 A/T - Vibration/Shudder On Light Acceleration 95228 NOV 95 Air Bag Warning Lamp - Incorrect Code 24 Diagnosis 95211 OCT 95 Air Bag Modules - Discolored/Marred Covers 95184 SEP 95 Air Conditioning - Approved Flushing Procedures 95182 SEP 95 Recycled Engine Coolant - Service Tips 95173 AUG 95 Park Brake Handle - Console Interference 951610 AUG 95 A/T - New Rotunda Fluid Changer Service Tip 95144 JUL 95 Ball Joint - Replacement Procedure Tip 95131 JUL 95 A/C Evaporator Core - On Vehicle Leak Test Requirement 95132 JUL 95 Temperature Gauge - Reads Low/Erratic 9593 MAY 95 Radio - Distortion/Poor Reception/Whine/Pop 9584 APR 95 A/T - AODE/4R70W Reusable Pan Gasket/Filter 9571 APR 95 Cowl Top Vent - Cracks at Washer Jet 9566 MAR 95 Blower Motor - Chirp/Squeak 9562 MAR 95 Brakes - Roughness During Application 9561 MAR 95 Paint - Iron Particle Removal 95512 MAR 95 A/C - Adding Refrigerant Oil Service Tip 95515 MAR 95 A/T - AODE Intermittent Loss of Torque at 3-4 Upshift 95313 FEB 95 A/T - 4R70W/AODE DTC's Set/Shift Concerns 9522 JAN 95 Air Conditioning - O Ring Removal Service Tip 9524 JAN 95 Radiator - New Manufacturing Process 9512 JAN 95 Accelerator Cable - Diagnostic Procedure ATRATB314 JAN 95 A/T - Delayed Engagement, Shift Errors, MLPS Codes ATRATB305 JAN 95 A/T - Shifts To Neutral At Heavy Throttle 94266 DEC 94 A/C - Release of R134a Fluorescent Dye 94269 DEC 94 A/T - AODE/4R70W Delayed or No Forward Engagement 94265 DEC 94 Headlamps - Removal Procedure Service Tip 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips 94252 DEC 94 Brake Rotor - Machining Equipment/Warranty Information 94235 NOV 94 Front Brakes - Thumping/Clacking Noise While Braking 942311 NOV 94 Outside Electric Door Mirror - Parts Return 94234 NOV 94 Paint - Preparation Procedure And MSDS Information 94233 NOV 94 Paint Failure - Reduced Chip Resistance 94206 OCT 94 A/C - Oil Visible At Spring Lock Couplers 94197 SEP 94 Ignition Switch - Harness Connector Non-Mating 94172 AUG 94 Rear View Mirror - Detaches From Windshield 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor - Application Chart 94137 JUN 94 Convertible Top Switch - Inoperative 94109 MAY 94 Engine - Rocker Arm Squeak/Chirp/Knock 941010 MAY 94 Lower Intake Bolt/Stud - Revised Torque Procedure 9484 APR 94 Air Bag - Diagnostic Trouble Code 12/52 9483 APR 94 `B'Pillar - Squeak From Top 9475 APR 94 Driveline - Boom Between 20 - 40 MPH 9476 APR 94 Fuel Line - Ticking/Tapping Sound 9478 APR 94 Ignition Control Module - Connector Update 9466 MAR 94 A/T - AODE/4R70W Shifting Concerns 9463 MAR 94 Fuel Pump - Noise Heard Inside Passenger Compartment 9453 MAR 94 Hood - Won't Release to Secondary Position 9428 JAN 94 Platinum Spark Plugs - Identification/Location 93261 DEC 93 Heated Backlite - Inoperative 93265 DEC 93 Power Steering System - Noisy 93241 NOV 93 Bumper Cover - Repair Materials Update 93248 NOV 93 Cooling System - New System Diagnostics 93244 NOV 93 Paint - Codes/Cross References 93243 NOV 93 Paint - Codes and Supplier Stock Numbers 93236 NOV 93 EGO Sensors - Silicone Contamination 93228 OCT 93 A/T - AODE/4R70W Orange Tag Service Procedure 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass ATRATB191 OCT 93 A/T - Failsafe Modes 9244 FEB 92 EEC IV - Self Test Codes and MIL Service Tips ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge ATRATB028 OCT 90 A/T - Engine Vacuum Testing ATRATB9002006 FEB 90 A/T - Choosing the Right ATF ATRATB8930 OCT 89 A/T - Math Part II ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs ATRATB8923 AUG 89 A/T - Math Formulas Part I ATRATB8754 SEP 87 A/T - Front Bushing Wear ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Threads Similar to: TSB Listing and recalls
| 2000 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 12 | January 23rd, 2009 12:54 AM |
| 2002 Mustang TSB's And Recalls | Casper98GT | 99-04 | 9 | November 26th, 2007 07:55 PM |
| 1998 Mustang TSBs and Recalls | Casper98GT | 96-98 | 8 | October 8th, 2007 09:04 PM |
| 1999 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 0 | September 5th, 2005 11:23 PM |
| 2001 Mustang TSB's and RECALLS | Casper98GT | 99-04 | 0 | September 5th, 2005 10:58 PM |
