Throttle Body
Old September 11th, 2007, 04:15 PM   #1
Snipe061 is on a distinguished road
Throttle Body
Can someone explain to me what a throttle body does, I know its probably simple, and also what is the stock size of a 95 V6 throttle body, and what would an increase in the size of it result in?
Old September 11th, 2007, 04:17 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
your gas pedal is attached to a metal line called the throttle cable.
that cable is connected to the throttle body.
it opens a butterfly valve allowing more air into the motor.
simply put.
Old September 11th, 2007, 04:21 PM   #3
Mustangfan99's Avatar
Mustangfan99 is on a distinguished road
+1, more air into your engine, the larger the throttle, the more air.
V6 power!
Old September 11th, 2007, 04:22 PM   #4
What is the largest size you can fit on a V6 and how much of an increase in horsepower are we talking here?
Old September 11th, 2007, 04:23 PM   #5
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
simply put.
+1 well put bro, and here i was about to get technical lol the thingy is connected to the lever bit that moves the shiny piece
Old September 11th, 2007, 04:24 PM   #6
HMUSN's Avatar
iTrader: 9 reviews
I wouldn't worry about it honestly man.
even the v8's done get much HP from a bigger T/B
you should be supercharged/Turbocharged to see any real gains.
Old September 11th, 2007, 04:25 PM   #7
Yeah i know that super/turbo charging is where the real power is, but for now i would just rather do bolt ons
Edit: oh yeah thanks for all the help guys
Old September 11th, 2007, 04:26 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
no .. what I am saying is.. the HP/$ ratio isn't worth it unless your blown.
you will see about 3HP from a larger one... if that if your N/A
Old September 11th, 2007, 04:28 PM   #9
rydog is on a distinguished road
Send a message via MSN to rydog
The largest you can put on yours without changing the upper intake is a 56mm
97 V6-GT40 turbo
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
Threads Similar to: Throttle Body
Throttle Body autoranch 96-98 4 August 7th, 2007 09:24 PM
throttle body? miles miles V6 Mustangs 4 June 1st, 2007 11:34 PM
bbk throttle body dumps 2005 - 2010 4 March 26th, 2007 08:02 PM
new throttle body? AFtriathlete General Tech 18 March 20th, 2007 01:14 AM
throttle body noppe180 96-98 2 November 4th, 2006 06:57 AM
