head gasket
i have a 95 v6 3.8l. im fairly certain ive gone and blown my head gasket. is there any way to be 100% certain? when i drive for an extended period of time my pistons start knocking due to the engine over heating. i would jsut get rid of it for a newer v8 but i just painted the car got and got new rims and i dont wanna just thro that away. Is there anyway to be sure its the head gasket and if it is how much am i looking at to repair it?
sometimes its ok to ignore the "suggested" speed limit |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
start by checking the oil, coolant, and a compression test.
well the oil isnt milky which is what ive heard happens in this case. and i had the whole cooling system flushed when i swaped out my water pump.
If its only misfiring at lower speed then its probably coolant getting into the cylinder. You wouldnt notice it as much at high speeds.
Did you check the oil when the car was hot or cold ? Any smoke from the tailpipe ? Does the exhaust gas smell sweet ? A couple more ways to check : 1)Take a sample of the coolant and go to the local radiator shop and request that they analyze the coolant for the presence of hydrocarbons. If they are present then it is most likely that you have a blown head gasket. 2) Check your plugs for a white reside/coolant 3) I heard some people take off the radiator cap (Do this when the engine is cool )Start the engine and race it. If there is a compression leak and the gasses are going into the cooling jacket then the gasses will displace the coolant. Since the cap is off the coolant will be pushed out of the radiator.
Fryrice has left the building. |
#5 | |
#6 | |
Of course don't drive around with the radiator cap off. Since coolant isn't getting into the oil the gasket isn't leaking between the water jacket and oil passageways, but it may be leaking between the water jacket and combustion chambers. |
Juggalo ,I didnt mean for him to drive around town like that. I meant while hes sitting still. Doh.
#8 | |
No worries. I could have worded it a little differently. I kinda looks like I meant race around town.
#10 | |
well when it over heats and the overfill cap is blown open and the radiator cap when i take it off coolant bubbles out
#12 | |
when it overheats the coolant boils out the radiator
You gotta explain more. It boils out after you have been driving it and after you take the cap off ?
another good way to check if you have a blown head gasket is if you see water coming out of your tailpipe
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
Threads Similar to: head gasket
| Head gasket size 82 302 | dreamr | General Tech | 1 | October 30th, 2007 09:05 PM |
| =( blown head gasket | itschristorres8 | V6 Mustangs | 17 | October 23rd, 2007 12:14 PM |
| Head gasket | nasty92LX | 5.0 Mustangs | 9 | September 13th, 2007 05:25 PM |
| 99 3.8 L Head Gasket? | Mike s | V6 Mustangs | 11 | November 13th, 2006 04:51 PM |
| head gasket | cali 5.0 | 5.0 Mustangs | 3 | June 20th, 2006 04:33 PM |
