2001 Mustang V6
gt takeoff exhaust idle volume
I just got a gt takeoff system put on my car 2 days ago and the idle volume coming from the tips is extremely quiet when the engine is warm. Its pretty much non-exsistant unless your ear is about 3 feet from the tip . I thought this was pretty weird considering that the stock muffler was about 2 times louder at idle. At higher rpms than idle (above 750rpm) it sounds great and has a decent purrr. If it helps, I dont have an H or X pipe, just 2 striaght mid pipes. I was just curious to see how many people who have had this system on their sixer have found the idle to be as quiet as a Honda?
2001 Laser Red V6 5-Speed -StangSuspension 1.4" Lowering Springs -GT Takeoffs -17" Mach 1 rims |
My Stallion is Bigger!
What kind of mufflers do you have on it?
an h pipe may give a slightly louder idle, my one friend had the same set up as you and had a slightly quiet idle, added an h and had a bit more purr to it.
V6 power! |
its quieter now because instead of all your exhaust exiting one pipe , you have 2 now. an h or x pip will help this a bit.
2001 Mustang V6
I have the OEM Mustang GT mufflers. Ok, so if I were to install a crossover pipe it might help a bit with the idle volume? Just curious. Thanks.
04 Mustang
or replace the mufflers with some flows and get an H pipe for a much louder and better sound
![]() Sponsor: Chips V6 Specialties < 2004 238C.I. 3.9L V6 Mustang Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit |
it sounds quiet becase its just the stock mufflers...now i had those with my offroad Xpipe and was O K but I def. wanted to change them...which I did to flowmasters...
just a V6 with a bad belt slip under the hood |
yeha man flows are a must have, mac also sounds nice.
V6 power! |
2001 Mustang V6
i was really wanting some mac's but i've looked at a couple places online and have yet to find just the flowpath mufflers. second choice would probably be some flow 80s or bassani bx mufflers (probably way too expensive). i like the gt mufflers so far, not too loud and not too quiet which is exactly what i was going for . unfortunately, there is an exhasut leak in the manifold so, whenever its in the 1000rpm to 2000rpm range, the go-kart like sound drowns out the soft purrr .
Threads Similar to: gt takeoff exhaust idle volume
| Transmission kicks down on takeoff. | fomocoro | 2005 - 2010 | 7 | August 8th, 2007 08:23 AM |
| Transmission kicks down on takeoff. | fomocoro | 2005 - 2010 | 0 | August 2nd, 2007 12:21 PM |
| stock compression ratio and combustion chamber volume??? | 83five0 | 5.0 Mustangs | 1 | May 15th, 2007 06:12 PM |
| Smoking On Takeoff | dbeller | 96-98 | 2 | October 3rd, 2006 07:23 PM |
| Cobra engine noise, shudder on takeoff. | Stavsig | 99-04 | 3 | July 29th, 2006 06:52 PM |
