Intake Manifold Swap help PLEASE!!!
Ok guys, i got a second job and i think ill be able to come by a split port intake or something of the sort. Im not sure whether or not i should get the split port, or a SCT tuner or what. I think i can do the split intake swap, but i need to know whether to buy the intake out of a newer 3.8, or to buy one from a company. Please, i need some help... would really like to learn about my little sixer.
split port will give you more bang for you buck first mod. get one off of a 01-04 v6 mustang.
#3 | |
2002 Summer Beater |
#4 | ||
#5 | |||
And don't mention the low end torque he'll miss. It's a v6 for god sake... Unless you're comparing it to a honda - V6s DON'T HAVE LOW END TORQUE.
#7 | ||||
#8 | |||||
#9 | ||||||
supercharger u perv
#10 | ||
[8MINUS2]
#11 | |||
#12 | ||||
[8MINUS2]
Not what that PM said .... Anyway moving on: If you do a splitport swap your more than likely going to need a tune to make it run correctly! So get both.
#13 | |
Mine has around 400ft/lbs at 3200rpms....... Maybe it should read ....NA V6s DON"T HAVE LOW END TORQUE
2003 Mustang Mach1 1995 Thunderbird LX 4.6L; 1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph |
wow lol... lets keep thr abbreviations slow for a retard. What all will i need to make the split port work, or will i be better off with supersix's manifold? no bottom intake work yet fellers, or supercharging. baby steps.
#15 | ||
V6 power! |
#16 | |||
To the OP: Baby steps yes, but you should have a final goal in mind. As it stands, modified single port heads out flow modified splitport heads when it come to performance. If I had a single port engine, I would not waste my time on the splitport mod unless I was going to stop modding there. To do the sp mod you'll need at least: heads, intakes (upper/lower), thottle body and any intake stuff, fuel injectors, injector harness, modified fuelrail (I think because of return vs returnless systems), a flasher/chip for a retune, vacuum lines, possibly a new MAF and Air Intake Temp sensor, and Throttle Position Sensor. I might have missed something. IMO that's a lot of stuff for a 40hp gain. BTW: I'm concidering swapping to single port heads because of their forced induction potential. But that's where my goal is taking me.
Honestly I dont care what anyone thinks about my ported lower and the gains I got...you also forget or not realize that I got a full on tune with it...the car also has flowmasters on it and not the stock GT mufflers...and is now on 93octane tune not 87...also timing was bumped 2 more degrees from what it was previously...make fun all you want...when u have someone who makes the programs...obviously he knows what hes doing...if you cant believe a Mustang Dyne...Then sure as hell dont compare a DynoJet with numbers....I cant wait till my plate is done...Im gona even here more bs with the numbers I make...
just a V6 with a bad belt slip under the hood |
#18 | |
oh and you do lose power on the low end like everyone knows...i dont recommend doing what I did on a NA engine...unless u have some built motor.....reason i did this was because i was bored and figured if i lose power low end idc...if i gain top end idc....i was just cutting time when putting the blower on....but i expected one dyno pass...not a full out set of runs and tuning...thats why i said why bring a video this time...though my HP numbers were lower on the baseline pull and my trq was higher then before...after some tuning my numbers started going back up...so i cant say exactly what the numbers are until I dyno again when its about 75-80 outside and not so humid...will be the closes thing to my 1st intial tune
#20 | |
Threads Similar to: Intake Manifold Swap help PLEASE!!!
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 21st, 2010 12:20 AM |
| need a intake manifold | matfernan1 | 99-04 | 22 | September 28th, 2007 12:54 AM |
| NPI or PI intake Manifold | 98SilverBullet | 96-98 | 1 | May 2nd, 2007 12:18 PM |
| intake manifold | burin_rubber | V6 Mustangs | 5 | March 27th, 2007 07:47 PM |
