Discussing torque specs in the V6 Mustangs Forum. 1996 and later Step 1................................................. .........15 Step 2................................................. .........29 Step 3................................................. .........36 Step 4................................................. .........Loosen ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
torque specs
1996 and later
Step 1................................................. .........15 Step 2................................................. .........29 Step 3................................................. .........36 Step 4................................................. .........Loosen 2 to 3 turns (DO NOT loosen all the bolts at the same time, from this point on work on one bolt at a time) Step 5 Long bolts............................................. ...29 to 37 Short bolts ...............................................11 to 18 Step 6................................................. .........Tighten an additional 180-degrees is that true? why would I loosen the bolts? |
#2 | ||||
Like a Boss...
2006 Mustang GT
In the 13's
what are you trying to do?
![]() Liberals are like cheese, they are full of holes, and stink. They lack the moral fiber to function as most of us do. When the world turns to chaos because of their actions, we will simply know them as food for the rest of us. JAKE'S PIITB CREW MEMBER#4
looks to be the head he is talking about.
you loosen the bolts a bit so you can assure a flush set onto the block. |
please be a little bit more discriptive of what you are trying to do.
V6 power! |
looks like the upper / lower intake bolts...is my guess...be more specific though like the others mentioned...also refer to the Sean Hyland guide online if there is a how to online...my friend ordered the Sean Hyland guide and its pretty useful with this subject showing pics and how to's with mustangs/cobras
just a V6 with a bad belt slip under the hood |
I am asking about the head bolts. in the chilton manual (what i copied and pasted) it says I have to loosen the bolts 2 to 3 turns before I complete the torque-ing. I wanted to know if this is safe to do and if it is necessary.
yes do exactly what it says for the reason I stated in my other post.
alright. thanks for the input!
no problem
so, do i have to get new head bolts if im just replacing the heads? (power pack) the car has less than 40k on it
I would.
Threads Similar to: torque specs
| 3.8 Torque Specs | Twist 2 Go | V6 Mustangs | 10 | April 24th, 2008 10:52 PM |
| Crankshaft torque specs anyone?? | stanglifemike | 2005+ | 18 | August 22nd, 2007 01:11 PM |
| Torque specs | G.T. Rags | 5.0 Mustangs | 13 | August 11th, 2007 11:47 PM |
| 4.6 Torque Specs | Twist 2 Go | Modular Mustangs | 27 | June 25th, 2007 07:12 PM |
| 5.0 Torque Specs | Twist 2 Go | 5.0 Mustangs | 1 | May 16th, 2006 12:52 AM |
