is this normal ?
Old September 17th, 2007, 03:07 AM   #1
stanged out's Avatar
stanged out is on a distinguished road
Send a message via AIM to stanged out
is this normal ?
when i start my car it idles around 900 rpms for a couple seconds then on its own it revs up to 1600 rpms then back to 900 and then back to 1600 to once again... all on its own , what could that be it didnt do it be4 ?? should i worry ?
Old September 17th, 2007, 03:13 AM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
clean ur iac, then clean the maf and all that stuff if its still doin it
SCT Mass Air Flow Sensor $200
Old September 17th, 2007, 03:17 AM   #3
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
use the search button
lemme go find instructions on cleaning that for you
edit
http://www.moddedmustangs.com/cleaning-your-iac.html
Old September 17th, 2007, 03:19 AM   #4
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
edit
thanks for doing my lazy work for as usual...
Old September 17th, 2007, 03:22 AM   #5
Onemanzu's Avatar
no problem ...
post count!!
im off to bed ni ni all
Old September 17th, 2007, 09:09 AM   #6
MustanG_guy17's Avatar
2007 Mustang GT/CS
MustanG_guy17 will become famous soon enough
Try changing you air filter.
2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD,Laser Veil G4.
MAVERICKS!!!!!!!!!! BABYYYY.. DALLAS COWBOYS
Old September 17th, 2007, 11:18 AM   #7
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
change filter
clean iac with throttle body cleaner.
clean your maf
if that doesnt do it u most likely have a vacuum leak or bad iac
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 17th, 2007, 11:24 AM   #8
how do you clean you maf and iac on a v6 those intruction up there.... wre they the same for a v6 ?? sorry im a noob at thisb
Old September 17th, 2007, 11:48 AM   #9
00 V6 & 09 GT
do you have an after marker intake on?
basically go to your auto store nearest you. grab some MAF cleaner and carb cleaner
your IAC should be located on the throttle body. 2 screw/s bolts hold it in place. remove them and disconnect the plug to it.
with the carb cleaner just spray it in there and clean it with that.
now your maf
located your maf. either take it out or it you have a after market intake take the pipe out.
you'll see 2 thin metal lines in the middle and between them at the end another prong. just spray it with the maf cleaner...NOT directly...spray at least like 5inches or so away
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: is this normal ?
Is it normal? Dawgfude03GT 99-04 4 November 5th, 2007 01:57 PM
is this normal in an intake? crappy_head 99-04 11 June 24th, 2007 12:04 PM
is this normal? spero 99-04 1 March 23rd, 2007 09:16 AM
Is This Normal? WilltheThrill Modular Mustangs 12 January 12th, 2007 03:28 PM
Is this normal? Please help!!! JAY'SRED02 99-04 16 July 6th, 2006 10:43 PM
