Discussing Longtube help in the V6 Mustangs Forum. I posted this in the Clubhouse, but I think it'll get alot better response ...
Old September 21st, 2007, 12:18 AM   #1
2000Mustang's Avatar
1998 Mustang GT
Longtube help
I posted this in the Clubhouse, but I think it'll get alot better response here. Id like you to tell me the symptoms of not filling in the rear sensors on LT headers so that I can diagnose my problems.
Off-road X pipe, Magnaflow mufflers, BBK cai, 3.73 gears, ZEX 75 shot (not hooked up), 17in. Bullitts, lowered
Old September 21st, 2007, 12:20 AM   #2
The Nice Guy
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
did you turn the sensors off in a tune? if not you will throw a CEL code or MIL code (same thing) your air/fuel can get fubared and you will have a shitty idle and shitty acceleration. its worse when the front pair go out though
ModdedAutos
1999 Mustang V6
Old September 21st, 2007, 12:23 AM   #3
1998 Mustang GT
That sounds like my problem. It has a fugged up idle and it is real sluggish. I put the O2's back in the front, but the rear bungs are just sitting there open. Should I weld it or get fake sensors? I do not have a tuner and I will not for a while. Can it run normal w/o a tuner?
Old September 21st, 2007, 12:29 AM   #4
The Nice Guy
14.79 @ 92.15
you dont need a tuner. you need real o2 sensors for the rear and you need MIL eliminators. it is cheaper this way. no it wont run normal without the correct voltage sent to the ecu
ModdedAutos
1999 Mustang V6
Old September 21st, 2007, 12:34 AM   #5
1998 Mustang GT
You mean that it win't run right with out the tuner, right? Can I use the stock rear O2 sensors? Will I have to extend the rears to make them fit too? And i'll need MIL eliminators either way, or only if I don't get a tuner?
Old September 21st, 2007, 12:38 AM   #6
MM's official Chevy guy
whitemustang02's Avatar
2002 Mustang V6
MIL's will only be needed if you have o/r mid pipe or very hi flow cats and extending them that will probable need to be done but cant say with out looking under the car and seing if the sensors will reach
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
Originally Posted by Heather View Post
Me likey mikey
Old September 21st, 2007, 01:07 AM   #7
SSStang's Avatar
2k2 Mustang V6
If you have long tubs & no cats, or o/r mid pipe then you need a.) MIL eliminators or B.) Tuner to turn off the rear 02 sensors
The rear sensors missing shouldn't make it run horrible
Selling for friend: Vortech Supercharge kit < 100miles.
Old September 21st, 2007, 01:14 AM   #8
1998 Mustang GT
I have LT's and high flow mini cats. It REALLY sounds bad when its starting up. And it doesn't run good at all. Any other suggestions?
Old September 21st, 2007, 01:17 AM   #9
02ponypackage's Avatar
exhaust leak ?
just a V6 with a bad belt slip under the hood
Old September 21st, 2007, 01:21 AM   #10
1998 Mustang GT
I honestly dont know. I dont think the little rear O2 bung would make that big of a leak.
Old September 21st, 2007, 01:23 AM   #11
SSStang's Avatar
2k2 Mustang V6
your mini cats have 02 bungs and their not plugged?
if not thats your problem.
Old September 21st, 2007, 01:25 AM   #12
i had one bong open and it was horrible...esp. when hitting the gas slightly...just annoying
Old September 21st, 2007, 01:28 AM   #13
1998 Mustang GT
No, the LT's have front and rear bungs. My rears are just open right now. Do I need to weld them or add 02 sensors?
Old September 21st, 2007, 01:30 AM   #14
add the sensors to plug them man
Old September 21st, 2007, 01:31 AM   #15
1998 Mustang GT
Add the stock sensors? If so, ill probably have to splice and extend, right?
Old September 21st, 2007, 01:32 AM   #16
i guess....i wouldnt think u need rear 02s unless u have emissions im guessing
Old September 21st, 2007, 01:36 AM   #17
1998 Mustang GT
Im not worried about emissions, I just want my car to run right.
Old September 21st, 2007, 01:40 AM   #18
leave no openings in the exhaust except the intlet and outlet thats all
Old September 21st, 2007, 01:42 AM   #19
SSStang's Avatar
2k2 Mustang V6
Your Long Tubes have 2 02 bungs? (2 on each header?)
Thats weird because the rear one would be pointless ....
Old September 21st, 2007, 01:43 AM   #20
yeah...they would...just like on my offroad Xpipe...they just fill the hole
Threads Similar to: Longtube help
BBK longtube install? TIM350 94-95 9 November 8th, 2007 11:05 PM
longtube headers! 98SilverStang 96-98 8 November 7th, 2007 01:14 PM
longtube trade... sivart Southeast 5 October 3rd, 2007 08:13 PM
Longtube exhaust javier351lx 5.0 Mustangs 2 July 11th, 2007 07:21 PM
Which Longtube Headers would you get Bigb2000GT 99-04 28 March 17th, 2007 03:02 AM
