Tips for better top speed and acceleration
I got a 2000 v6 mustang for my 16 b day and i need help making it a lil better off the line and just making the car a better overall ride
1999 Ford Mustang V6
for quicker off the line...look into changing the gears and adding t-lock w/sct tune. for the better ride... get a takeoff rear sway bar from gt, new shocks and struts, maybe some lowering springs.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
14.79 @ 92.15
FRPP Trac Lok and FRPP 4.10:1 gears for the 7.5" rear
SCT XCal 2 Remove front sway bar, lower, shocks/struts supercharger Well top speed won't change much, because of physics, you can not really achieve theoretical top speed, but for acceleration, the front sway bar is just extra weight, and here is how to take it off for free in under 30 minutes. The other mods are pricey and require professional installation (except the SCT XCal 2)
is the front sway bar remaoval bad for the car, or are there any cautions to take if u remove it?
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
14.79 @ 92.15
You will get some body roll into turns, but the wheels stick to the pavement better and you wont plow into corners, you will actually spin the rear end all the way around more than plow through the front end. You get less weight up front, better weight transfer during launch, and after readjusting to a more sporty drive stlye, a better ride for free. You must be careful though- if you begin to lose control, you don't hit the brakes to straighten up, without a front sway bar, you must gas it and power through a spin.
is it a total notice? or slight until u lose control
and is it easy to do for idiots like me, to take off and put back on if i don't like it for some reason? i read ur write up, i will refer to taht if i want to take it off
14.79 @ 92.15
Total notice. When turning left, my car dives down to the right. If I just start at a standstill, turn the wheel all the way left and hit the gas, I will do a donut without a brakestand. It is complete night/day, but worth re-learning the car.
Maybe I will take a video tomorrow of my car through a hard corner to show the drastic change
haha good call maybe ill take it off and see if i like it!!!
what should i get first one of my friends told me to get one of the racing chips first and cold air intake first is that correct
from what i have been reading... gears is the best bang for the buck so id go with those, thats my next or an intake for 160 on ebay, demolet tunable intake
14.79 @ 92.15
You will need a tuner (not chip) to change the gear ratio for the ecu. You can continually reflash the ecu with a tuner with future modifications. I would get a trac lok and rear end gears first.
i have 700 dollars what should i buy first
gears/trac-lok, SCT TUNER
14.79 @ 92.15
You will need just a little bit more than 700 to complete the rear end gears/t lok. you can buy the parts all new for 700, but install of the gears at a shop is 200.
okstatefan, are you in oklahoma? if so, i would reccomend you use jim at www.swtuning.com to install your gears. the guy knows his shit and has great customer service. tell hm i sent ya over there!
#17 | |
14.79 @ 92.15
Yes, but because of weight transfer, it is exxagerated and more easy to occur. Take off your front sway bar and go at about 15 mph and turn the wheel hard, your car body will dive down hard to one side and spin the rear around. Stock, it would plow the front tires in an understeer... removed front sway bar is actually oversteer. From a stop- no much difference- the difference is when driving.
#19 | |
personally id rather just add a rear bar to get the oversteer, i hate body roll
14.79 @ 92.15
I did it for the oversteer and for the weight loss/weight transfer. Adding weight to my car would only make it slower...
Threads Similar to: Tips for better top speed and acceleration
| want more acceleration!!! | 93mustanggtauto | 5.0 Mustangs | 25 | October 16th, 2007 12:15 AM |
| Acceleration Stumble | Juggalo_X | V6 Mustangs | 3 | June 13th, 2007 03:30 PM |
| Vibration on acceleration.... | lwhitetrash88l | V6 Mustangs | 6 | March 31st, 2007 08:50 PM |
| need tips on what engine to put in my 95 mustang 5 speed no | 1stMustangCobra95 | 5.0 Mustangs | 7 | October 17th, 2006 04:54 PM |
| Stutter under acceleration | Goose | 5.0 Mustangs | 6 | August 7th, 2006 02:36 PM |
