Discussing 4.0L nitrous in the V6 Mustangs Forum. I have a 2006 mustang with a 4.0L V6. Pretty much stock. I can ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
4.0L nitrous |
#2 | |
Moderator
8.876@80.013 1/8th
Don't limit yourself to just NOS products. Look at NX, Zex, Venom, etc. They all make good products. Now it doesn't exactly go by this will give you 50hp or so. What regulates how much nitrous is used is a jet. To start off with a stock engine I would play it safe, and use a 75 shot, and get it tuned. I myself am not a nitrous guru unlike some of the people on this site. They can explain all this a lot better than I can.
So I'm told a wet kit is better for your engine.
Blue Mustang Society click it
Yeah, I am not sure what HP is good for a stock engine. I am just looking for something to give me a good HP boost. I see some people talking about a system and having it be able to "Purge", does this feature come with all kits, or just some?
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
a purge valve allows you to clear your nitrous lines of any air so you get a pure shot of nitrous when you hit it.
not all kits come with it. I would invest in it though honestly. Stick 100 shot on her and get a tune and you will be fine.
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
Now when you say a tune, what do you mean? do you mean buy a tuner, or is there a different kind of shop tune that I need?
19.83 @ 12mph
buy a tuner.
make sure to buy the tuner that your local dyno shop has the software for.
OK, now I understand NOS, however I am not sure, do you only use it at high speed with a switch, or does it hook up to the gas and the RPM for automatic injection.?
As far as a tuner goes, are there any suggestions as to which one? I see SCT, but I see the Diablo is cheaper! |
19.83 @ 12mph
the kits normally have an arming switch and should only be used at wide open throttle.
either tuner is good. it's not the device that is better... it's the person tunning your car with it that makes the better tune. I would use what your local dyno shop uses
i dont think i have any "local" dyno shop down here in miami..
http://i154.photobucket.com/albums/s...do/rims008.jpg |
#10 | |
2k2 Mustang V6
However, don't start off with a 100shot. Start with the 50 or 75 jets then work your way up to the 100 after your comfortable with it. Wet shot is generally better because it combines the fuel with the nitrous so your computer doesn't have to worry about compensating. Their are also guys who have been running one of Justin's Mail Order Tunes on nitrous 6's for a year +
What is a mail order tune.. I also and not sure if we have a local dyno here in Utah either. Why would I start at 50 HP, just to learn how to handle the power or to break the engine in?
Also, if I use a 75 shot, will it ruin my engine faster. it is 06, so, I do not want to ruin anything. |
#12 | |
Location: looking for free hand jobs in poland springs nebraska... silly gooses
okay funny story i would like to share... i watched a video on streetfire that had a v6 rental mustang that they put a 125 shoot on... of course it was a rental but it managed to keep up with a new edge GT...
what i guess im getting at is you can do a 75 -100 shoot safe no problems... make sure you tune it and to get a lil boost in numbers on top of that do some other supporting mods the reason they say start low and work your way up is that you don't do something stupid like push your cars limits and blow it up in one run... though your car is pretty stout... some have run 15+ psi on it stock... so it can hold make sure that you get all the other things they have mentioned and don't push the button to much
slow car club - crew member 8 of 9
So I need to get a NOS system, and use a 75 shot. buy a tuner and tune it for NOS. Now when you say 15+ PSI, are you talking NOS or turbo?
#14 | |
2000 Mustang V6
shot for nitrous
psi for force induction (turbo/super) i think u will be better with an SCT.. get the tunes by mail and u will be ok.. in americanmuscle.com theres a nice zex kit for startes i think it comes with almost all the parts needed and its wet shot..
if you look at some of the descriptinos of the NOZ it says to not use an aftermarket advance timing, as it might cause detination with the NOS? any truth here?
19.83 @ 12mph
yea you should not advance your timing.
you'll ping that way.
but when you tune it for power, and 91 octane, does that not advance the timing?
I thought that is how a tuner worked, is that it advances the timing. If you do not advance the timing, how does a tuner give you power? |
#18 | |
by controlling other various components in your computer and engine... other then just timing...
Threads Similar to: 4.0L nitrous
| Nitrous | Goblin | Poweradders | 0 | November 12th, 2007 03:42 PM |
| nitrous | mustangboy8909 | 5.0 Mustangs | 6 | July 29th, 2007 09:33 PM |
| K&N CAI, Nitrous kit, nitrous accessories | Timber | Air/Fuel | 12 | June 28th, 2007 10:35 PM |
| what do you think of nitrous | Badasstang281 | 99-04 | 51 | January 7th, 2007 06:07 AM |
| Nitrous ?'s | bwb3 | 5.0 Mustangs | 5 | November 27th, 2006 04:31 PM |
