Replacing Fuel Pump
2000 85k miles auto
next week im going to order a focus pump. what i wanted to know is there anything else i need in order to make the swap? and also is there to find out if something else is wrong?(fuel pump relay, injectors) |
yeah i know which pump to get. but do i need anything else. i looked at the cobra tank swap tutorial on here. so do i basically just follow those steps and I'll be fine or is there anything i need to worry about when swapping out just the pump?
![]() Pioneer Sound System (Comp Speakers-Amp-Deck) - Viper Alarm/Remote Starter Eibach Pro Kit - Smoked CC Headlights - 18" Bullitt Wheels - SVT Focus Fuel Pump True Dual Exhaust - Flowmaster Original 40s - 3.5 Rolled/Slanted Tips |
Just swap out the pump and be done with it, you could always put a thicker gauge power wire on though. That will allow for less voltage drop.
Custom engine built from Super Six, Cam from Delk performance, Custom Novi 2000 in the works. My Car www.supersixmotorsports.com www.bc-automotive.com/ |
#5 | |
The Focus pump is a plug-n-play.
Have you heard of any problems with the Focus 310 pump? I think over on SVTPref the talk is using the Ford GT pump instead of the foci pump. Some modifications to the bucket and wiring are required, but they may flow more using less current. And I heard they were cheaper than the Foci.
2002 Summer Beater |
I have yet to hear of a problem with running the focus pump. How much does the GT pump push? I thought the V6 and GT shared the same pump.
#7 | |
I need to do more research.
I really have no idea with that at all. I know when you could always upgrade the FDM and that helps with the current.
check this out
i took 2 trips yesterday both on the freeway. the first trip was about 30 miles to there and back home. i had no problems watsover. i took a second trip about an 1 hour later. i drove about 14 miles to get there no problems. on the way back about halfway through my car just started slowing down. i stepped on the gas but nothing. i was in the 4th lane so it was a bitch pull over. finally i managed to get the fuck outta the way of oncoming traffic until my car just came to a stop. i waited about 2 minutes in the trouble lane, then i started the car w/o any problems. i was able to reach the nearest exit. i stopped at mickey ds and grabbed a bite to eat for like 20 min or so then drove my ass home no problems
#11 | |
I know I tried for 5 minutes to get the filler tube out of the tank and it wouldn't go. That's why I changed my pump with the tank hanging. In my Ford workshop manual CD it says,"Note: A new grommet must be used for the installation procedure due to its destruction during removal." You have a 2000. May be it's different for my 2002?
[8MINUS2]
The focus pump will burn out on the 99+ mustang, its recomended for the pre 99's
The pump of choice for 99-04 is the 310 from vmp tuning -
#13 | |
¡ʇsnq ɹo uʍop ǝpısdn
for a 96-98 you will want a 255 lph from walbro
#14 | ||
[8MINUS2]
who said it was better... the svt pump is for the return-less the walbro is for the return... thats all i said... read much? punk!
#16 | ||
#17 | |
#18 | |
I dont get why you can check SVTperformance for an SVT focus fuel pump and people only have 255 "SVT focus pumps" and not 310s...which doesnt make sense...i thought they had 310s
just a V6 with a bad belt slip under the hood |
the SVT has a 310 pump the 255 pumps being referred to are the walbro 255's
they are different systems and require different parts that is all... while you are under there look into a new filter to just to be on the safe side
Threads Similar to: Replacing Fuel Pump
| fuel pump | musclepony | 5.0 Mustangs | 1 | August 15th, 2007 02:15 PM |
| new fuel pump | beheivjer | Modular Mustangs | 5 | May 21st, 2007 09:33 AM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
| what fuel pump set up to go with? | 02ATIstang | 99-04 | 6 | April 24th, 2007 07:28 PM |
| Replacing An Oil Pump Without Pulling The Motor | JamesR1 | 5.0 Mustangs | 1 | September 17th, 2006 01:57 PM |
