Rear End Size
Old August 5th, 2006, 07:06 PM   #1
cdunc24's Avatar
cdunc24 is on a distinguished road
Rear End Size
I recently bought a 97 V-6 that had a 302 put in. Are the rear ends the same size for the V-6? if not, how do I tell? It measures about 9" around and has 10 bolts on the gear cover, I don't know if that helps. Also the drive shaft, were they the same for V-6 vs. V-8? Thanks in advance.
Old August 5th, 2006, 10:11 PM   #2
stang fanatic's Avatar
stang fanatic is on a distinguished road
the only thing different would be ring/pinion ratio. rear was set up for 6 not 8. its a 8.8 rear 28 spline axles
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 6th, 2006, 02:00 AM   #3
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
If it is a 7.5" rear, it will have rounded sides
If it is an 8.8" rear it will have squared sides
All 7.5s have the same ratio, but fox, sn94, new edge, and s197s have different axle lengths.
here is some great info
ModdedAutos
1999 Mustang V6
Old September 22nd, 2006, 01:59 AM   #4
Replica R's Avatar
Replica R is on a distinguished road
Hey do you guys know where I could find an 8.8 rearend for a 99 v6. Or do you know of anyone who makes them with your desired gear ratios already installed into them.
Friends Don't Let Friends Drive Rice!
Old September 22nd, 2006, 08:20 AM   #5
14.79 @ 92.15
junkyard for a wrecked gt of same year gets you a rear, and then buy gears for the 8.8 you get. it bolts right up
ModdedAutos
1999 Mustang V6
Threads Similar to: Rear End Size
V6 rear end size 95wip 94-95 2 May 12th, 2007 02:35 AM
rear-end size Sam'sWildStang V6 Mustangs 3 February 17th, 2007 12:16 PM
Rear end size VDub1285 Modular Mustangs 2 January 16th, 2007 03:05 PM
94 GT what size rear end? stang94 5.0 Mustangs 2 December 6th, 2006 09:31 AM
94 GT what size rear end? stang94 5.0 Mustangs 0 December 6th, 2006 09:09 AM
