Discussing PCV valve bypass in the V6 Mustangs Forum. on the supersixmotorsports webstie they talk about by passing the pcv valves? is there any ...
Old October 11th, 2007, 11:25 PM   #1
motorhead6776's Avatar
2003 Mustang
PCV valve bypass
on the supersixmotorsports webstie they talk about by passing the pcv valves? is there any performance benifit to this? if so how much?
Old October 11th, 2007, 11:47 PM   #2
blazor's Avatar
bump, im curious too. what does it do exactly?
-01 V6 Coupe 5 Speed
-02 GT Convertible 5 Speed
Old October 12th, 2007, 03:02 AM   #3
¡ʇsnq ɹo uʍop ǝpısdn
Positive Crank Ventilation... thats what pcv stands for ... honestly i can see that freeing up a lil bit of vacuum can maybe have some benefits but they put that on cars for a reason... to suck all the miscellaneous gases out of the top of the valve covers... and this idea has been around for ever...
now on the other hand i have heard of and EGR delete being slightly beneficial too ... might look into that
Old October 12th, 2007, 01:20 PM   #4
2003 Mustang
ya i was looking around and i found that deleting the pcv valve on v6 mustangs between 99 and 2004 actually help the engine run cleaner because it happens to suck oil into the intake.
also it throws off the air fuel ratio because it lets unmeasured air into the engine because they dump into the intake after the airflow sensor.
still not sure about the performance benefit...
Old October 12th, 2007, 01:28 PM   #5
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
99-00 they had a pcv issue where it was tossing oil into the intake causing a misfire on cyl 3 and 6 the 2001 valve cover was modified to prevent this. also on a low vacume situation the pcv valve closes for example under WOT.
Old October 12th, 2007, 01:33 PM   #6
Juggalo_X's Avatar
14+@Slow
PS> the air the pvc valve vents from the crank case IS metered by the maf. if u didnt know the PCV has an intake tube after the MAF by the TB
Old October 12th, 2007, 01:37 PM   #7
Juggalo_X's Avatar
14+@Slow
here is a good read for any one who dont know the purpose of the PCV system. its beneficial to your car you MUST have a way to vent crank cast gazes or it WILL dammage your engine. but there are more ways to vent crank case gazes effectively with out the use of a PCV valve :wink
Click
Threads Similar to: PCV valve bypass
WTB: VORTECH MINI RACE BYPASS VALVE 02SCGT Want to Buy 0 August 18th, 2007 03:10 PM
Bypass pulley mich_mustang88man 5.0 Mustangs 0 July 26th, 2007 10:03 PM
BOV vs BYPASS PERFORMANCE bransdaman78 Power Adders 10 May 9th, 2007 05:14 PM
SC Bypass jdm2007 2005 - 2009 13 May 6th, 2007 06:46 AM
FS: Vortech Mini Race Bypass Valve mdvaldosta For Sale 4 March 14th, 2007 02:41 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
