will these fit?
i found some rims i kinda want on my car. just wonderin if these will fit?
http://seattle.craigslist.org/see/pts/444647256.html
Well Hello, they call me Mr. Insano. |
I don't know they look to wide to fit on, they would probly go on the back no problem but they may rub in the front. The max width of a rim that will fit on the front of your car is 9". Phone the guy and ask him. Good Luck
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3. |
how wide and how high can i fit on the back...and how high can i have on the front?
![]() Shift Kit K&N fuel injection kit Mach 460 stereo system custom gauges |
Here's a good resource that should tell you all you need to know.
http://www.americanmuscle.com/simple...de-wheels.html
1998 Mustang Coupe
Amazing
![]() ![]() iTrader: 2 reviews
i think that if you get wheels over 18in. you have to get your car reflashed
It's not completely nessacery. Your speedo and odometor will be affected slighty, also for an automatic trasmission shift points will be slighly altered and your performance will shift aswell but not at a noticeable amount.
