tuner and gears ,tloc help?
I have a 2004 mustang convertible v6 auto with a CAI and dual flowmasters. I was wondering if i ordered the SCT xCalibrator 2 tuner from mustangtuning.com and had them costume make a tune already for my car if it would work perfectly fine? I was also wondering in the future if i wanted to add 4.10 rear gears and a tlock then would that be a problem having the tuner already installed? or could the shop that installs the tlock and gears just fix my speedometer n all that with the sct and still keep my same tune?
yes it would work fine... the tuner will help u adjust the speedo for the gear change
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
but it won't mess up my tune i already have right? just fix the speedo
what do u mean? u already got a tune on it? or when u do have a tune on it then do the gears, and recalibrate it? wont mess a thing up
I just wasnt sure what all i would have to do with the tuner after i put the gears and trac lock in besides fix the speedo
Thank you |
with the tuner ull need to program ur ecu showing u have what ever gear ratio and then i wanna say recalibrate ur speedo, not fully sure but u should be fine, im sure AB will be here to give u the correct answer if i may be wrong
k thanks
1999 Ford Mustang V6
the xcal2 gives you the ability to correct the gear ratio for the future install, without having to get a new tune. you can change just your gear value
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
ok thats what i was just making sure off.. and its the same thing for wheel/tire size right?
10-4
Threads Similar to: tuner and gears ,tloc help?
| tuner or gears? | miles miles | V6 Mustangs | 15 | June 6th, 2007 05:34 PM |
| tloc and 4.10 | miles miles | V6 Mustangs | 11 | June 5th, 2007 06:51 PM |
| tuner and gears | adam0421 | 2005 - 2010 | 4 | March 9th, 2007 09:44 AM |
| Tuner adjust for my gears? | Blue98GT | Modular Mustangs | 4 | January 1st, 2007 05:16 PM |
| ? (Tuner For Gears) | Mustang Mike | 99-04 | 7 | December 21st, 2006 09:34 PM |
