my mustang dies....
Old October 22nd, 2007, 10:49 PM   #1
RhadCundell's Avatar
RhadCundell is on a distinguished road
Send a message via AIM to RhadCundell
my mustang dies....
ok so this is the third time its happened..
ill be driving..2 times down the high way and once about 5 min ago..
when the car starts bogging..like if i were to have the A/C on or something..
but it boggs..then eventually it just dies..like bogs and when i press the gas..it doesnt accelerate so after i pull it over everything is still on..my brights..radio..subs..four-ways..
so its not my alternator..
so maybe a fuel pump...i hope not =[
the car will start back up after a few minutes
Old October 22nd, 2007, 10:51 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
did you check the alternator and battery to see if they are holding charge and remaining charged? just because it starts back up doesnt mean it isnt going bad.
ModdedAutos
1999 Mustang V6
Old October 22nd, 2007, 11:00 PM   #3
but like all of my stuff works fine..
like id think my lights would dim
Old October 22nd, 2007, 11:02 PM   #4
MM's official Chevy guy
2002 Mustang V6
whitemustang02 will become famous soon enoughwhitemustang02 will become famous soon enough
Send a message via AIM to whitemustang02 Send a message via Yahoo to whitemustang02
a simaler thing hapeneed to my dads old park ave and i can't remember if it was the fule pump, or regulater
"Speak softly and carry a big stick" - Theodore Roosevelt
"Any idiot can make a V8 fast, it takes a real idiot to make a fast V6".
'02 Mustang N/A 4.3 stroker away for winter
'72 Chevelle project car 454 coming
'93 Bronco EFI 351W DD
Old October 22nd, 2007, 11:20 PM   #5
im hopeing its not any of that
Old October 22nd, 2007, 11:32 PM   #6
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
check the spark plugs as well but if it was them it would be really jerky
Old October 22nd, 2007, 11:34 PM   #7
ya i can do that
itd be nice if thats all it is
Old October 23rd, 2007, 12:01 AM   #8
thetrooper31 will become famous soon enough
Send a message via AIM to thetrooper31
do you have enough gas....i ran out of gas once...and it did that =(
[SIZE=5][COLOR=Yellow][/COLOR][/SIZE][COLOR=green]
[/COLOR]
Old October 23rd, 2007, 12:06 AM   #9
ya
lol
unless my gauge is fucked up..
idk
but i have to store it for winter =[
in my uncles barn
so ill have plenty of time to do whatever
Old October 23rd, 2007, 12:07 AM   #10
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
it sounds like its lacking gas... thats what cars do when they run out... they bog when you gas it and just flat out suck nuts...
Old October 23rd, 2007, 12:09 AM   #11
ya it sucks..
bad
and its embarrassing when your sitting on the side of a highway..
Old October 23rd, 2007, 12:11 AM   #12
Onemanzu's Avatar
you should check all your wiring and such... check the grounds and shit for your fuel pump and what not... see if something is going on there... also change your fuel filter
Old October 23rd, 2007, 12:12 AM   #13
ya
ok no making fun off.
where are the grounds located?
idk this is also the 2nd time its died in the rain
coincidence?
or could that be something else
Old October 23rd, 2007, 12:18 AM   #14
Onemanzu's Avatar
for the fuel pump?? just check all the connections that you can see and fell under the car... DO NOT drop the tank or anything... to big of a pain just to check something... but just look over the wires to make sure nothing is loose
Old October 23rd, 2007, 12:20 AM   #15
aight ill do it after school
hopefully everything is ok
and it is just some wires
Old October 23rd, 2007, 08:51 AM   #16
ahh
well went to go to school..
and i get about 3 houses down..and dead..
wtf?
this is getting ridiculous
im hopeing its just gas....
cuz otherwise ugh idk
Old October 23rd, 2007, 09:02 AM   #17
Moderator
This could be bad gas. Where do you normally buy your gas? If it's from some shit hole, try a different place, and run premium in it for a couple tanks. WHil doing so, try adding something like STP water remover, and then add some STP fuel injector cleaner. Don't put both in at once. Fill up the tank, then add the water remover. Run the tank down, fill it back up then add the fuel injector cleaner. With both products, put the entire bottle in to a full tank of fuel.
It's also possible that you have a bad fuel filter. Try replacing that if the above doesn't fix your problem, since it's a cheap fix.
If that doesn't fix it, it could be the fuel pump as already stated here. It could also be a bad injector.
It's also possible that you have a bad coil, although the symptoms you describe lead me to believe it's the fuel system.
Does the car otherwise run perfectly other than when it's misbehaving? Or have you noticed this coming on gradually, or noticed an increase in fuel consumption, and a loss in power?
Old October 23rd, 2007, 09:27 AM   #18
well i think it was the gas..
i went to the gas station and put some gas in it..
and its running now....
so idk my gauge is messed up ..
how about fixing that?
i get my gas from whereever is closest..aha
mostly BP
cuz its closest to me ..
Old October 23rd, 2007, 09:33 AM   #19
Moderator
Cool. Nice when it's not a major thing. I would still run some STP through it just to be sure man.
Are you sure your gauge is messed up? If so, could be a bad ground, as someone stated here, or it could be the sending unit in the tank. Which is a pain in the dick to replace.
Old October 23rd, 2007, 09:37 AM   #20
aha ya
its a relief
i mean this morning i started it and drove about three houses down and it died..
and started right back up but as soon as i pulled back in my driveway it died..
so i took my moms car and got some gas
came back put it in my car..and i took it out and ipened it up cuz i was pissed..aha
and its fine now..
but my gauge reads i have a lil under a quater tank..and i put ten in on sunday..and maybe went...no more then 70 miles on the 10 running errns
Threads Similar to: my mustang dies....
Car Dies While Driving (Help!) TFI? bigred2k 94-95 4 August 24th, 2007 03:12 PM
dies at 3k superman5.0 5.0 Mustangs 7 July 18th, 2007 06:26 PM
Starts and Dies RDR61 5.0 Mustangs 4 July 4th, 2007 11:11 PM
97 mustang gt dies for no reason. Help! hamburgerpatty 96-98 5 August 27th, 2006 07:43 PM
Car dies out Espo General Tech 1 August 22nd, 2006 02:21 PM
