Smog Pump Delete?
What do i need to do this and why do they make fenderwall intakes if this is in teh flippin way? UGHHHH i was so happy
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
1999 Ford Mustang V6
you should be able to use the fenderwell intake with your smog pump, i had my MAC version installed with mine equipped, but later deleted it due to failure of the pump. basically there are 2 electrical connections with a air tube, if you disconnect you will throw a few codes, the CEL can be turned off in the tune or by "pulling the bulb" (not advised). if you ever sell the car by federal law you must disclose that you disabled or tampered with the smog equipment. if you choose to delete it, i would do the EGR at the same time, cap the header bungs and plug the egr holes on the upper intake manifold. if you remove the pump and don't get your PCM reflashed it will not produce any adverse reactions other than more pollutants and the pesky CEL. i will post up a few pictures of the smog pump it'self.
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
smog pump picture (exterior)
RLY SRS
Mine went in just fine with no problems...Is this something that is only there on the V6's or did they change it pre-2002?
Like I said I had no issue at all... |
mine went in fine too, but it was tight to attach the filter to the intake tube... also if i'm not mistaken there is another smog pump design that looks more like a brake booster... not all v6'ers came with smog pumps, only the one's with the "california emission's package". but the smog pump resides in the passengerside fenderwell... so if you are having problems, just unbolt it and move it to the side then re-install?
yea the smog pump is totally in the way... and i can't run the intake unless it gone? what are the pros, cons to the smog and egr delete?
RLY SRS
Oh well I guess that makes sense...My car was built in PA...
so i can just unbolt it move to the side and put the filter on then put the pump back on or just delete it all along
ill try it tomorrow i have to go to work now but i may have to ad an extension peice cuz the the turn down is right where the pump is... damnit smog bastard
with my MAC CAI kit the filter was directly on the opposite side of the fenderwell, are you saying your kit has a turndown inside of the fenderwell hole? if not i would just unbolt the smog pump it put on the filter and rebolt it back up...
#13 | |
), cleaner intake track due to not recirculating the exhaust gas into the upper manifoldcons: check engine light, increased emissions, possible failed inspection for missing smog pump (but unlikely), slightly decreased fuel economy, will have to cap egr ports on UIM or use block off plate, will have to cap smog bungs on oe exhaust manifolds.
i see, he has that demolet tunable cai... man it looks like you gotta send it back or relocate/delete the smog pump, unless you want to configure it with the filter inside the engine bay which defeats the purpose of the "fenderwell induction".
#16 | |
RLY SRS
not sure, does your smog pump look like mine (pictured above)? maybe his filter is longer? maybe the demolet tubing is slightly diff on the v6 models compared to the gt's or cobras?
RLY SRS
Its raining right now but I will take a pic tomorrow...But I did not have any problem with the install...
im gonnna try to move configure something out maybe adding more plastic to go under the smog pump... ill take a good look at it tomorrow. My boss who builds cars said maybe just turn the tubes into the engine bay if it works... otherwise ill have to rig it somehow
Threads Similar to: Smog Pump Delete?
| Smog Pump Delete? | 5-0stank | 5.0 Mustangs | 20 | July 14th, 2008 04:24 PM |
| SMog pump delete kit | javier351lx | 5.0 Mustangs | 9 | August 20th, 2007 02:24 PM |
| smog pump delete | bigwhiskey | 5.0 Mustangs | 4 | June 30th, 2007 11:02 PM |
| How To Delete Smog Pump On 95 GT | the95..5-0 | 5.0 Mustangs | 2 | September 13th, 2006 12:43 AM |
| Smog Pump Delete | mdvaldosta | 5.0 Mustangs | 2 | September 11th, 2006 11:13 AM |
