I think my starter is going...
Ok so long story short. I talked to my wife the other day and found at that the day before this whine started in the car, the car was at a light and she thought she stalled it so she cranked the ignition 3 times, but the car didn't stall so the engine was already running and there she was cranking it over. So the next day I go out to take the car out (95 Mustang) and there's a whine up near the window on the passanger side. Now, the sound is only there when the car is cold and rarely, when I go to start the car it has a hard time starting, but when it does that and it does start there's no whine. So either it starts right away with a whine or struggles and doesn't so I'm thinking she messed up the starter. What do you all think? Where exactly is the starter on the 95?
Sounds like she blasted the starter gear that engages the flywheel. Get the car up in the air and pull it off and check it. I believe on your car it's on the passenger side, at the rear of the engine, butted up against the transmission bellhousing.
Make sure you disconnect the positive terminal of the battery before disconnecting the starter connections. |
Could also be the flywheel ive seen a starter grind the shit outta its self and a fly wheel from over starting.
:homo
When you get the starter off you will be able to see the flywheel teeth with a light. You can spin the motor over by turning the harmonic balancer at the front of the engine with a socket & johnson bar. Turn it clockwise bit by bit as you check each section of flywheel. Easier if you have a friend to turn it for you as you look. p.s. always use jackstands to support the car while you're under it. |
#5 | |
I won't be doing any of this myself as I'm not in any way a mechanic. I do have a brother in law who can take care of this for me. Is this going to be a costly thing to fix?
If it's just the starter, no.
If the flywheel is damaged, yes. However, these things are designed to where the gear on the starter is a softer material than the flywheel, so normally just the starter gear is damaged. Normally. |
Well I'm normally pretty good at diagnosing car issues and I'm rather sure that it's the starter just from the story I was told and what's happening with the car. I'll start with the starter and move on. I appreciate the help.
Anytime man, best of luck fixing her.
Engine's stop only in two positions which is why it would only happen part of the time.... sorry but if I had to guess I would say it's the flywheel!
Oh but I would be pretty sure the bendix gear on the starter is also damaged due to being made from a softer material! Had a 300Z at our shop with this condition 2 months ago! |
Engine's do not stop in only two positions.
Tell me why if you look at a older flywheel it will only have 2 very worn spots on it? And when I say two spots I am only refering to the flywheel !!
They are natural points for a engine to come to a stop after removing fuel and spark due to compression. |
tell me you're kidding me right..
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
¡ʇsnq ɹo uʍop ǝpısdn
i think thats kinda stupid but makes since??
this guy sounds like a mechanic... ha but what do they know??
WOW... guess I am the only one who had starter grind on a flywheel that rotated 1/2 turn and had it happen there too, but on the 1/4 turns it's ok.
On a used flywheel it is the first thing I inspect. |
If Lasota racing says I am wrong I will listen.... but not from someone who had to pay a shop to tune their car.
I had a guy a few years back that got so pissed at me for not doing a warranty on his starter that he threw it at a curb till the case broke... made him buy a new starter... guess what?....same problem ( flywheel )
and your whoring why??
lets just say for now that its the starter... either which way it will need to be replaced flywheel or not
I am open to anyone that can prove my statments wrong...... I am only going on all the old school rules that were taught to me ( and personal experience)..... please tell tell ME!
I am only saying inspect flywheel before putting in new unit!
Threads Similar to: I think my starter is going...
| starter | notsoslow50 | 5.0 Mustangs | 6 | August 21st, 2007 10:47 AM |
| STARTER help please!!!! | Replica R | Audio/Video | 3 | June 25th, 2007 03:02 PM |
| Need Help A.S.A.P! (Starter) | sn-95aac | 5.0 Mustangs | 13 | February 28th, 2007 08:32 PM |
| Starter for my car! | dblindberg | 2005 - 2010 | 8 | January 12th, 2007 08:10 AM |
| Starter or Starter Relay | cobralini | 5.0 Mustangs | 7 | August 3rd, 2006 06:34 PM |
