3.8 Rod Bearings
Old August 15th, 2006, 07:30 PM   #1
T_O_A_D is on a distinguished road
3.8 Rod Bearings
Howdy all
Just found your forum Lots of good stuff in here.
I tried your search feature with no luck to my question.
I'm rebuilding a stock 1993 3.8 for my Daughter to drive daily.
When I bought the bearings they have no oil hole for the spray hole in the connecting rod.
The originals did, is this something that Ford and teh aftermarket have decided is no lnger needed?
I have asked two Ford Garages and in todays reman, plug and play world the had no clue. (Those are bearings it calls for Duh!)
Even the parts distributor has no answer.
I know in my experience there are alot of engines out there designed with out the sprayers, but in this one Ford put them there for some reaason and I would assume they would want them used, short some updated revision or something.
Any help will be most appriciated.
Thanks T_O_A_D
Old August 15th, 2006, 07:38 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
those may be bearings for the 3.8 thunderbird supercoupe if i recall correctly some had oil sprayers? what brand are they, part#? you need the bearings with the holes, you can order them from here: http://rpm-mustangs.com/cart/home.php?cat=348
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old August 15th, 2006, 07:43 PM   #3
also if your looking to add a little pep check out the list of v6 part reseller/mfg's.
Old August 17th, 2006, 09:29 PM   #4
Thaks for the reply, trying to find some Clevites locally.
Old August 17th, 2006, 11:25 PM   #5
sounds good if you run into a snag or have a question about them, i would shoot mik an e-mail... that is the owner of rpm, he very helpful
Threads Similar to: 3.8 Rod Bearings
wheel bearings RC02GT 99-04 1 August 15th, 2007 07:20 PM
I'm getting new rod bearings..... HOORAY!!!! acmillr 99-04 44 July 2nd, 2007 09:36 AM
Knocking. Not the Rod Bearings???Pls Help! tweeaks V6 Mustangs 18 May 18th, 2007 01:38 PM
wheel bearings jagstang96 Modular Mustangs 4 January 12th, 2007 11:01 PM
wheel bearings and suspencion jagstang96 Modular Mustangs 0 January 10th, 2007 08:40 PM
