x-cal 2 install
Old November 1st, 2007, 07:39 PM   #1
Ridinlow6969 is on a distinguished road
x-cal 2 install
i just received my x-cal 2 that i ordered from bamachips and i had a few questions. i noticed in the instructions it says this.."First disconnect the fuel pump and electric fan fuses" where do i find these at? the next thing i was wondering is will it show on the tuner the name of the custom tunes i ordered such as performance or torque tune or will it just show something like programs 1,2 and 3. and will it save my stock tune by itself or is there an option i have to go to for that. hope someone can help me with this,i don't really want to start messing with it until i know for sure what im doing,lol
Old November 1st, 2007, 07:51 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
it will show what you named the tune.
it will also automatically save your stock tune.
the fuses are under the hood in your fuse box.
be sure that you pull them.
Old November 1st, 2007, 07:53 PM   #3
will the fuses be labeled wut they are?
Old November 1st, 2007, 07:56 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
it should show what fuses are what once you take the top of the box off.
look at the bottom of the lid.
Old November 1st, 2007, 08:12 PM   #5
ok i found the fuses but i see 2 of them for the fuel pump. ones a 15amp fuse and the other is labeled as a micro relay. its one of the big square grey fuses,do i remove them both?
Old November 1st, 2007, 08:29 PM   #6
so does anyone know if i need to remove the fuse and the relay or just the fuse?
Old November 1st, 2007, 09:11 PM   #7
HMUSN's Avatar
iTrader: 9 reviews
remove both.
Old November 1st, 2007, 10:05 PM   #8
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
You don't have to remove either -
Hi, You can call me Kyle
Old November 1st, 2007, 10:06 PM   #9
HMUSN's Avatar
iTrader: 9 reviews
^ you should.
if your battery dies while downloading your fucked.
Old November 1st, 2007, 10:12 PM   #10
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Originally Posted by HMUSN
^ you should.
Your battery would have to be at less than 2% to die
Old November 1st, 2007, 10:15 PM   #11
HMUSN's Avatar
iTrader: 9 reviews
and your fuel pump or fan coming on would easily Drain that 2 %.
they are automatically controlled by your ecu.
unless you pull the fuses they can come on even with the car off.
why take the chance?
Old November 2nd, 2007, 01:29 AM   #12
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
ive had my fan come on while installing a tune...it'll drain
[SIGPIC][/SIGPIC]
Acmillr loves me
Old November 2nd, 2007, 03:51 AM   #13
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
yep pull the fuses. while tuning both the fuel pump and fan come on and dont shut off till the tune is done. Not sure why but yea thatd be why they tell you to pull them
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Old November 2nd, 2007, 03:57 AM   #14
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Guess i'm the only one with a decent electrical system
Old November 2nd, 2007, 09:24 AM   #15
00 V6 & 09 GT
they go on in all cars...its suppose to happen
i guess your the only one with a bad electrical system
[SIGPIC][/SIGPIC]
Acmillr loves me
Old November 2nd, 2007, 12:05 PM   #16
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
pulling the micro relay isn't needed... pulling just the fuse will over ride the relay making it not come on
Old November 2nd, 2007, 12:10 PM   #17
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Definitely pull the fuse the PCM must have a steady 24v feed if it happens to fluctuate your going to have a dead car. Its very possible and has happened MANY times, allot of ppl have fucked there pcm flashing it. Especially when you DO NOT follow the instructions provided by the tuner manufacturer, like some ppl with red cars here do :wink
Old November 2nd, 2007, 12:12 PM   #18
Juggalo_X's Avatar
14+@Slow
I also remember back when some one programed there PCM with SCT and did not follow the instructions and there car ran like a bag of shit. was that you christorres??
Old November 2nd, 2007, 12:13 PM   #19
Onemanzu's Avatar
but yall... he has a livewire which doesn't require to be pulled cause it is ment to be plugged in and ran while the car is running the only thing for him is he has to plug it in while the car is off then turn the car on after its plugged in then he is good to go...
Old November 2nd, 2007, 12:17 PM   #20
Juggalo_X's Avatar
14+@Slow
yah when the car is running and he ISNT flashing the pcm. when you are flashing the PCM SCT states you should disable the Fuel pump and Cooling fan to prevent PCM flash misshapes. Sniper dont recommend to unplug these and i still do because i know if that pcm gets a hiccup then im fucked.
Threads Similar to: x-cal 2 install
How to Install a Top TurboLX General Tech 8 March 1st, 2011 01:46 PM
*^$ HOW DO I INSTALL *^$ mustang1072 V6 Mustangs 4 September 27th, 2007 12:45 PM
CAI install jabrennan V6 Mustangs 22 March 10th, 2007 03:30 AM
sub and amp install GreenFaleen Audio/Video 17 January 4th, 2007 01:40 PM
HID install help geekstang 99-04 1 August 26th, 2006 05:17 PM
