Glorious PC gaming master race
Vibration
when im goin down the interstate my steering wheel will start vibrating at around 65 mph... any ideas as 2 why? ive recently put new rims and tires on and im thinkin that might b y but i cant figure out y that would affect it...
1999 Ford Mustang V6
14.79 @ 92.15
the wheels may be out of balance. is it when you apply the brakes or just constantly? does the car itself vibrate or just the steering wheel move back and forth?
its just the steering wheel... i dont see how they would be out of balance because it was balanced before i put them on and then i had my front end aligned... its kinda getting annoying...
and it does it constantly once i hit about 65
alignment or balancing could really be the only thing i believe. i say balancing or bad tires
#6 | |
causes of tire vibration: Warped rotors Caliper not returning/Stuck pins Suspension is damaged or worn. ie: tire rod ends, ball joint ect... Bad Wheel bearing. excessive play in stabilizer or control arm bushings. Out of round tire, the belt has slipped. Over inflated tire(s) Out of balance tire(s) Warped rim uneven tread wear due to alignment issues or issues stated above. Un-even break pad wear Lose or improperly installed/torqued lug nuts. Missing lug nuts. |
as a personal opinion, and from experience. most high speed vibrations are usually slipped belts or bad breaks matinance
¡ʇsnq ɹo uʍop ǝpısdn
Warped rotors - only when braking from any speed
Caliper not returning/Stuck pins - maybe but more so if braking then not Suspension is damaged or worn. ie: tire rod ends, ball joint ect... tie rod ends could be a good culprit Bad Wheel bearing. - same ^^ excessive play in stabilizer or control arm bushings. - same ^^ Out of round tire, the belt has slipped. - huh? Over inflated tire(s) - do a quick check Out of balance tire(s) - unlikely Warped rim - new rims uneven tread wear due to alignment issues or issues stated above. - new tires Un-even break pad wear - happens more so when braking Lose or improperly installed/torqued lug nuts. - do a quick check Missing lug nuts. - unlikely
#9 | |
refer to the bold: when this happens you will know it lol ever seen an egg shaped tire?? :wink not cool |
#10 | |
MM's Database Error
Re: vibration
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
idk what is makin it do that but i drove around a little bit yesterday and it didnt do it so idk wut 2 do...
14.79 @ 92.15
if it happens again, note the exact conditions: i.e. brakes applied, turning, road condition, accelerating, coasting, etc.
my wheel shakes when i go fast on a shitty road, but once i hit a good patch of fresh pavement it stops completely... maybe your just experiencing road vibrations?
that could be it... the highways near my house arent in the best condition. i went on some back roads yesterday and gave it some hell and i didnt notice anything.
#16 | |
you sound like my co worker who just bought a car he has the new car paranoia
no i bought the car in april of 06... ive put a little bit of money in it since then so i might get a lil paranoid from time to time
#18 | |
2007 Mustang GT
Say something very scary today...
Hi there!
First time posting. My 07 GT has had the same issue but I found out MY cause. I'm good from 30 mph to 135 so far. I wonder, are you using the rim from Ford M-1007-U1885P* the 2005-07 MUSTANG GT WHEEL POLISHED? I don't want to go off the deep end first thing but it took about 6.5 oz of weight to the out side part of the rim to get 2 of my wheels ballenced today. I had to use a trick from my sound renforcement training and Sherlock Holmes to see it but I know what MY issue was and judging from all I've read it might be yours. 1st things first , are you using those rims? Thanks RJ |
im using the 17 inch bullit style rims off of an 07 gt
Threads Similar to: Vibration
| more vibration | graystang01 | V6 Mustangs | 3 | November 13th, 2007 10:11 PM |
| vibration | haywood11 | 5.0 Mustangs | 2 | October 28th, 2007 08:41 AM |
| Vibration | shurb125 | 5.0 Mustangs | 13 | May 8th, 2007 09:23 AM |
| vibration | cali 5.0 | 5.0 Mustangs | 7 | June 8th, 2006 07:44 PM |
| vibration | cali 5.0 | General Tech | 2 | May 31st, 2006 05:09 PM |
