Discussing IMRC in the V6 Mustangs Forum. Ok soi have an IMRC problem....one of them is stuck i tried to unstick ...
Old November 5th, 2007, 12:50 PM   #1
IMRC
Ok soi have an IMRC problem....one of them is stuck i tried to unstick it using carb cleaner, throtle body cleaner...everything!!sowebnesday im going toford to get it fixed......can something be done while there doing that to help performance.........or not really...obviously without costing to much $$$$$ more!!!
The difference between Fiction and Reality???
Fiction has to make sense.
-Tom Clancy
Old November 5th, 2007, 12:52 PM   #2
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
how did you spray carb and throttle cleaner into your IMRC?
The Sickest 6
The reason V8 owners on here hate me
Old November 5th, 2007, 01:24 PM   #3
oh sorry...the easiest way is to do it thru the intake while lightly reving the motor!!!!
-Tom Clancy
Old November 5th, 2007, 02:31 PM   #4
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
and you think thats safe?! or a good idea....
lol omg i cant believe you seriously tried that...i thought you ment you took off the upper intake and lower and sprayed it...
with the motor on you sprayed that?!
The Sickest 6
Old November 5th, 2007, 03:43 PM   #5
MM Ninja / Site Moderator
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
whats so unsafe about using carb and tb cleaner while revving the engine?
Now to the OP:
1) How do you know the IMRC is stuck?
2) have you considered sea foam?
Modded Autos Join today, All makes all models
Originally Posted by drgnracin72 View Post
fat girls dont expect dick, they apreciate it...
Old November 5th, 2007, 04:26 PM   #6
SSStang's Avatar
2k2 Mustang V6
Now to the OP:
I have an idea what chris is getting to :p And spraying or seafoaming wont get them unstuck normally....
Selling for friend: Vortech Supercharge kit < 100miles.
Old November 5th, 2007, 04:32 PM   #7
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
nothing TOO unsafe
lol just pointless
also say the carb cleaner hits a valve..gets some carbon off and that gets trapped in the valve face and seat....now you have a problem
its not common obviously but its possible none the less
The Sickest 6
Old November 5th, 2007, 04:41 PM   #8
Juggalo_X's Avatar
14+@Slow
nothing TOO unsafe
lol just pointless
your correct but like you said this isnt commonly an issue. and if this happened what i would do is pull the plugs and put a bit of sea foam into the suspected cylinder and then give it a crank with out the plus in it, it will wash the valve face and seat hopefully and toss the excess seafoam out the exhaust valve and the plug hole. cant do this with a plug in, it wont crank cant compress a liquid :wink but i have seen this method before to clean shit out of the cylinders.
Note: remove all plug wires and plugs. also this is a last ditch effort before pulling the head.
Old November 5th, 2007, 11:19 PM   #9
SantanielloITA's Avatar
lmao i would never do that
2000 black mustang 15.6 1/4 (stock)
Now-CAI, Autolite spark plugs, JBA wires, 99 svt cobra rims, (Duals, gears, t-lok and 75 wetshot comin soon)
Old November 6th, 2007, 11:34 AM   #10
Juggalo_X's Avatar
14+@Slow
why not, i have the engine running and manually rev the TB while i add seafoam or TB cleaner all the time. it dont hurt it, just chugs and runs like a bag cuz ur flooding the engine a bit and ur also creating a vacume leak from applying the cleaner.
Old November 6th, 2007, 11:38 AM   #11
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
the vacuum leak is the big part that makes it chug and gurgle
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old November 6th, 2007, 11:42 AM   #12
Juggalo_X's Avatar
14+@Slow
yes sir :wink
Old November 6th, 2007, 11:50 AM   #13
MM Phantom
Onemanzu's Avatar
you need to stop being a post whoring ass hat of a mod
Old November 6th, 2007, 11:52 AM   #14
Juggalo_X's Avatar
14+@Slow
your one to talk and as a side note my co-workers brother is a mechanic and he said there is a tool you can get that screws onto the top of a seafoam can and then plugs into a vacume line and allows the engine to idle and slowly draw in the intake cleaner with out causing a bad vacume leak there for making it clean the engine better and run better as your doing so.
Old November 6th, 2007, 11:56 AM   #15
MM Phantom
Onemanzu's Avatar
w.e your a hater of my good looks butt nugget!!
i will have to look into that... i gotta seafoam it this next oil change...
im thinking about getting one of the gallon sized things and using it to help clean the engine
Old November 6th, 2007, 11:57 AM   #16
Juggalo_X's Avatar
14+@Slow
how much shit is in ur engine?
Old November 6th, 2007, 12:05 PM   #17
MM Phantom
Onemanzu's Avatar
well lets see...
152k+
uhh once lived in the country ...
i was about a month late on my last oil change you know you got a dirty car when an oil change helps the performance of your car
also had a oil and coolant leak causing some oil water mixing...
can't wait to see the smoke show... oh and just fyi ... seafoaming doesn't work on lawn mowers to well
Old November 6th, 2007, 12:12 PM   #18
On Probation
Hourofpain's Avatar
1998 Mustang Gt
14 MPG
dont forget about all the inbred children
Old November 6th, 2007, 11:58 PM   #19
Thanks for the help Jug!!!! i appreciate it!!!
^^^^ u shut the f*** up when u have no clue what the f**** ur talking about!!!!!!
-Tom Clancy
Old November 7th, 2007, 10:31 AM   #20
Juggalo_X's Avatar
14+@Slow
dude wtf, take it easy there is no need for that we are only trying to help.
Threads Similar to: IMRC
parts for imrc cobraglenn 96-98 1 April 18th, 2007 04:52 PM
Can a sct programer retune Imrc cobraglenn 96-98 3 April 10th, 2007 03:30 PM
IMRC cobraglenn 96-98 0 March 25th, 2007 10:45 PM
98 cobra 4.6 4v imrc deleting 98whitecobra 96-98 3 March 23rd, 2007 05:52 PM
Need IMRC Plates daleboeski Modular Mustangs 1 October 11th, 2006 10:27 PM
