Car wont start!?!?
Old November 6th, 2007, 08:47 PM   #1
SantanielloITA's Avatar
SantanielloITA is on a distinguished road
Send a message via AIM to SantanielloITA
Car wont start!?!?
I have a 2000 v6 mustang auto. and today i went to drop off a friend from school and i got out to look at a tuner for my car. when i started to leave i went to turn on my car and it wouldnt start. I had someone come over today to look at it and he said when i went to turn it on he saw no spark at all he said its probably an electrical problem but he wasnt 100% sure..
if anyone knows please reply back thanks!
2000 black mustang 15.6 1/4 (stock)
Now-CAI, Autolite spark plugs, JBA wires, 99 svt cobra rims, (Duals, gears, t-lok and 75 wetshot comin soon)
Old November 6th, 2007, 08:53 PM   #2
2000 Mustang V6
El_Cangri will become famous soon enough
Send a message via AIM to El_Cangri Send a message via MSN to El_Cangri
go with the basic first...
is the battery good?
Originally Posted by Fryrice
One time I stuck my dick in my own butt by accident.
Dont laugh it was dark in the room.
Old November 6th, 2007, 08:54 PM   #3
Battery is fine we tried it and its all good
Old November 6th, 2007, 08:59 PM   #4
2000 Mustang V6
do electronic turn on and the motor doesnt?
Old November 6th, 2007, 09:25 PM   #5
the motor basically wants to go but it wont start
Old November 6th, 2007, 09:31 PM   #6
97stanger is an unknown quantity at this point
How did he conclude that their was no spark? If you have no Spark, it's probably an easy fix...Coil Pack/ Ignition coil...whatever you want to call it. Sometimes they do randomly just go bad. Before you go out replacing it though...before, when it was running, was it running good? Didn't sound weird? If it sounded weird, and it has no spark, its prolly your timing is off.
Originally Posted by BWAL09
aww, you fucking piece of shit, you are making me get all fucking emotional now
Old November 6th, 2007, 09:33 PM   #7
I ran it at the track and ran 15.6 stock and just drivin around normal it runs perfectly fine.
Old November 6th, 2007, 09:35 PM   #8
Old November 6th, 2007, 09:38 PM   #9
he opened up the hood and looked at the spark plug and he told me to start it a few times and he saw no spark then he tried it and i saw no spark
Old November 6th, 2007, 09:41 PM   #10
Did he use an in-line ignition spark tester? Or did he just pull the plug and have you turn it over? Another possibility would be to check your fuel pressure. Just turn the ignition to the on position and find your schrader valve on your fuel rail and press it. Fuel should squirt out about 4-5 feet. the equivalent of 50 psi (thats what the pressure should be on your car). If yuo have little or no fuel coming out, then it would be 1 (if not fuel is coming out) Fuel Pump 2. (Little fuel coming out) Fuel Filter.
Old November 6th, 2007, 09:42 PM   #11
I have gas in the car, the battery is fine to me because all my lights work and my radio, so i dont think its the battery
Old November 6th, 2007, 09:44 PM   #12
You can have a full tank and a bad filter or pump and it wont start. And its not your battery because its turning over. Now, if its not turning over as fast as usual, that COULD cause it not to start and have a very low spark.
Old November 6th, 2007, 09:45 PM   #13
no he just pulled the plug and had me turn it on... i didnt try that because its dark outside i just got my car inside the garage which took forever all the way from a friends house... we have been tryin to see what the problem would be.. so i made a post on here for extra help
Old November 6th, 2007, 09:48 PM   #14
All lines connected? If your intake hose is not connected to the intake, than that will cause it not to start due to the MAFS. But, im going to go with one of 3 things...Ignition coil, fuel pump, fuel filter.....And hell, i could be wrong, and it could just be that you need new plugs and wires. Did the plugs look clean?
Old November 6th, 2007, 09:51 PM   #15
they look fine i just bought autolite spark plugs like 2 days ago and i was thinkin about changin the ignition coils but idk ill go check the intake and fuel pump where was the rail where i push it and fuel should squirt out?
Old November 6th, 2007, 09:51 PM   #16
Have one of your friends lay under the gas tank. You get in the car and shut the door (so your door alarm is not sounding). turn the ignition to ON. When its on, your friend should hear a pump turn on from inside the gas tank. If he hears nothing, switch places. If you hear nothing, beat on the tank ( dont worry, you wont break it). If you still dont hear a pump turn on and the car wont start, you need a fuel pump./
Old November 6th, 2007, 09:57 PM   #17
Now, while your listening for the fuel pump, you gotta listen hard, because you will only hear it for about 3 seconds. The Schrader valve is on the Fuel rail. Its prolly behind a cap. It looks like an a/c feed line for 134a. the red arrows are for the screws that you have to remove to get the cover off. the line underneath with the green cap is A schrader valve> NOT THE ONE THAT YOU NEED. But, its to give yuo an idea what to look for on the rail. Take the cap off of the one on the Fuel rail and press the core in with a phillips screw driver.
Old November 6th, 2007, 10:00 PM   #18
Shit, sorry, thats the wrong picture. Thats of a Cavalier fuel rail. Let me try and find one for your car. Sorry about that. You can also just follow the fuel line to the engine...That will lead you to the fuel rail.
Old November 6th, 2007, 10:04 PM   #19
i heard somethin gmove in the gas tank i just tried it
Old November 6th, 2007, 10:13 PM   #20
im probably gonna buy new spark plug wires tommorow and im gonna try to disconnect the battery and terminals and wait about 10 mins and re conncet everything to see if that would work
Threads Similar to: Car wont start!?!?
Wont Start caintcatchmyGT 96-98 3 September 11th, 2007 12:02 AM
wont start snailstang 96-98 24 August 30th, 2007 10:46 AM
need help...car wont start orlyr21 V6 Mustangs 8 January 13th, 2007 09:17 PM
wont start?? shadowgames81 5.0 Mustangs 10 January 7th, 2007 10:10 PM
91-92 5.0 gt wont start sturcotte3 5.0 Mustangs 0 January 1st, 2007 06:40 PM
