Discussing Bad Gas Mileage, Need Help in the V6 Mustangs Forum. alright i just bought some seafoam and put it in the tank. i put 16fl ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
2004 Mustang V6
alright i just bought some seafoam and put it in the tank. i put 16fl oz and filled the tank up. well ill report in a couple days and see what my gas mileage is. btw when i checked this time i was 14.57 mpg.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock. |
#22 |
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
how much did you fill up?! if your only filling a certain amount of gallons..then you divide by the gallons you've used
#23 |
slow
What RPM range is best for mileage? I've been trying to stay in the 1,500 range.
E-bay CAI H-pipe/flowmasters40's/3" slant-cut tips http://www.veoh.com/videos/v4150679NMr4r4n6 |
#24 | |
2000 Mustang V6
the better rpm range for mpg is the lower u can do w.o damaging the car..
here its the 1.5-2k range
#25 | |
2004 Mustang V6
#26 |
1965 Mustang Fastback
im getting 12 miles a gallon
![]() im gonna go buy sea foam tomorrow see if that helps i have a 302 but yea i think i should get better than 12.... i |
#27 |
2004 Mustang V6
dang 12 mpg that sucks but ur engine is way bigger. yea hopefully i will get better mpg now specially with gas prices going up like crazy. im gonna clean the maf again this weekend and spray some throttle body cleaner in the throttle body and see if that helps any.
#28 |
2004 Mustang V6
seafoam is the shit. i went from 13-14 mpg to 18 mpg and then to 21mpg (thats with highway/street). i havent even cleaned my maf and throttle body yet. just thought i would update u guys.
#29 |
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
seafoam
air filter (K&N filter or ebay intake) change your fuel filter im getting 18-19mpg with turbo and that was gunning it a few times as well as a bad tune. you should be around 18-22 |
#30 |
I ended up putting almost a half a can in on a quarter tank of gas. This was about 4 weeks ago (2,000 miles) and it didnt hurt a thing. Im not sure if I noticed a mileage increase but definately a smoother engine. With gas prices going through the roof, I hoped it helped a little.
K&N FIPK Dual Flowmasters Xcal III Christmas Gifts! http://www.moddedmustangs.com/forums...s-candles.htmlPROFESSOR JA candlestick maker millenium |
#31 |
1998 Mustang Coupe
Amazing
so how often do you put seafoam in your car........every tank you use or every couple of them?
and what is the price on the stuff |
#32 |
2005 Ford F150 FX4
i had the same problem before. i went from 20 mpg to 11mpg.
You said it got cooler. this could be your problem. The temp here in montana dropped down to like 40 degrees and that is when i got 11. If you have a cai, it will hurt your mileage if it gets to cold outside. At least that is my experience. Just my 2 cents. take it for what it is.
2005 Ford F150 FX4-New Toy MM Truck Crew ![]() 2002 Ford Mustang V6-Sold ![]() 1997 Ford Mustang V6-Sold |
#33 |
my girlfriend has been getting 17 mpg's lately. her k&n intake was crap because it kept falling off the TB. this is why we thought she was getting bad mileage. so we bought an ebay intake that goes in the fender and has a nice boot for intake tube to TB, it doesnt fall off the TB now but it seems gas has gotten worse. now she's getting about 15 or less. yes the weather is cold, about 10 degrees some nights and she put weight in here trunk because of snow for traction(180 lbs of sand). but do you think it should be this bad?? i mean its still a 6cyl. i have an 8cyl 350 and im still getting 13-14 lately with a 4400lb car!
#34 | |
1995 Mustang convertible
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
#35 | |
2004 Mustang V6
the seafoam did definitely help. no i wasnt doing any more city driving than usual and i havent changed my driving style so higher speeds/ rpms should be the same.
#36 |
1998 SVT Cobra
Depends on the motor - the Cobra gets a significantly better mileage turning 2300 rpm than 2K (like 26 vs 22). It's one of the biggest reasons I'm gonna put 4.10s in that thing as soon as I have the money to.
*The Sacred Chao says "MU"* Real racers turn corners... both ways... on the same track. MM Corner Carvers Crew, member #2 |
#37 |
On Probation
1998 Mustang Gt
14 MPG
have you tried changing your spark plugs
chagningg your fuel filter btw im not reading the rest of this thread |
#38 | |
2000 Mustang V6
get a tuner get some h.p and mpg!
and wow this is old
#39 |
Good I'm glad to hear that the seafoam helped. Did you just put in your gas tank or did you put it in the crank case as well? I'm going to seafoam my car within the next few days. We'll see how much it helps.
#40 |
i actually went out and bought seafoam today for myself and my girlfriends car. she was still getting 15mph after today. got 43miles on 3 gallons of gas so thats not too good still. fuel light came on so we went to the pumps, put the full can of seafoam in the tank and put about 10 gallons of gas in. says it treats 8-25 gallons of gas with one bottle, so we just made it a super heavy concentrate. i also took one of the sand bags out too. i figured with spare tire,2 60lb bags of sand and crap in the trunk is about 150lbs. i think thats enough weight in the trunk no? idk we'll see in a couple of days how her mileage is doing with the weight drop and seafoam in the tank. post really isnt that old is it?? like 3 weeks?? decided to use the "search" button like people would ask me to use if i asked about it. just thought id bring up old conversation and it seems we've even enlightened a member to also try this amazing seafoam as a test. so ok *break* report back in a few days men...move out!
Threads Similar to: Bad Gas Mileage, Need Help
| V6 gas mileage | Racerchik02 | The Clubhouse | 62 | June 12th, 2007 08:23 PM |
| 4.10 gas mileage | mikedoogen | 2005+ | 7 | March 20th, 2007 03:44 PM |
| Gas Mileage with 3.73s... 4.10s?? | wormster00 | 2005+ | 21 | March 6th, 2007 02:21 PM |
| mileage | bcp5008 | V6 Mustangs | 20 | December 19th, 2006 11:01 PM |
| Gas mileage ? | MustangMatt | Modular Mustangs | 3 | December 18th, 2006 12:32 PM |
