need help with diag
Old August 19th, 2006, 12:24 AM   #1
Crazyj32's Avatar
Crazyj32 is on a distinguished road
need help with diag
hey guys, so today i ported and halfshalfed my throttle body and got it all right except im having one problem with it, when im in gear and rev to 2k+ rpm and put it in neutral (manual trans) the rpm's dont drop until i slow down at least 10 mph, it idles fine when stopped, i rev the engine while in nuetral stopped and rpm's drop right back to 800, but only when im moving and in nuetral do they stay high, and check engine light is on. but still drivable as long as im in a gear. please help with diag. ty
chek it out.
http://www.cardomain.com/ride/2396814
Old August 19th, 2006, 02:20 AM   #2
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
go to an autozone, and have them scan it for free not worth guessing when u don't have to pay for it , after u get it scaned bring it back here and im sure ull get an answer quick
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old August 19th, 2006, 03:36 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
make sure you didn't port where the butterfly touches the bore, if you remove material there, the car will always idle high and eratic?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old August 19th, 2006, 05:01 AM   #4
Crazyj32's Avatar
rpm isnt very eratic, its steady at whatever rpm i was at when i switched to nuetral, but ill hit up auto zone tomarrow and let you guys know whats goin on and well see what i gotta do, i hope i dont have to get a new butterfly valve. but that may be the case.
chek it out.
Old August 19th, 2006, 12:54 PM   #5
i would try reseting the computer... do you have an aftermarket chip/re-flash? does the same thing happen if you unplug the IAC?
Threads Similar to: need help with diag
Need help with diag codes Gunny 2005 - 2010 7 August 17th, 2007 01:40 PM
