cheap ways to mod your 3.8/3.9 split port
I started about 2 months ago just messin around with different items on my V6. I did some Lightening and also some very cheap mods, some were free.
I started by polishing my throttle body and half shafting it, this allows for smoother air flow into your motor and a slight increase of HP. Its a very simple proceeder as long as you have a Dremel tool ( it takes alot of explaining so i will only tell if someone asks. Then I made a rear strut tower cross bar, All you need is a piece of High strength steel and flatten the ends out at the correct length ( I had to buy some 10mm nuts and lock washers for that one). then, for those with a '99-'04 mustang, I cut open my fake hood scoop ( once again i used a Dremel, and remember a dust mask) I used Hardware cloth to create a screen to fit in the newly opened hole. this ONLY allows more cold air into the engine compartment( it helps your engine run cooler and keeps your intake from sucking up as much warm air). If you have any questions on how any of this is done just ask, I like to help. |
¡ʇsnq ɹo uʍop ǝpısdn
hey dude... try this mod ... take off your air silencer on the intake box... if you still have it thats a great first mod its so cheap and makes the woosh noise that a CAI makes
[8MINUS2]
And out of all this you will gain 1.578 hp
I already removed that, in fact i bought a cheap aluminum tube from auto zone and, it took alot of modding but I got it in there with the original aircleaner box
its not HP gain that i was going for it runs alot smoother now
another use for your dremel.....
I recently bought a small cylinder hone ment for really small cylinders ( like lawnmowers or dirtbikes) i put in on my dremel and ran that thing up and down all the ports on my upper and lower intake, I even removed the freeze plugs and did the plenums on the upper.......its well worth it and only costs you the hone and the time, alot of time |
Threads Similar to: cheap ways to mod your 3.8/3.9 split port
| KB or Whipple on a split port? | Ninjawafers! | V6 Mustangs | 70 | October 27th, 2007 07:32 PM |
| Split port swap | wannabeimportkiller | V6 Mustangs | 17 | August 6th, 2007 02:00 AM |
| Single Port vs. Split Port | One Bad Sixxx | V6 Mustangs | 24 | June 2nd, 2007 10:26 AM |
| single port to split port | 94pacecarSVT | V6 Mustangs | 5 | February 2nd, 2007 12:25 AM |
| Split port | Cricket | V6 Mustangs | 6 | April 24th, 2006 11:53 PM |
