Uhh Help! (Alternator)
I think i screwed up my Alt. I'll accelerate over 3k and the lights go dim until the car shifts and sometimes the bat. light comes on. I'm not sure how many amps my Alt. cranks out but ill check tommorow but will a alt from a GT work on my car? cuz i have my subs and a much of interior lights runnin off the alt, any suggestions on amperage sizes? Thanks much aperciated
#2 | |
MM's Database Error
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
04 Mustang
+1 sounds like your subs are killin your alternator
![]() Sponsor: Chips V6 Specialties < 2004 238C.I. 3.9L V6 Mustang Dual Exhaust,Shaved GT Bumper,Tinted Lights,8000K HID Kit |
MM's Resident Ricer
2006 Scion tC
13.001@113
your alt is toast and everytime that battery light comes on your car changes to battery power so your killing your battery too.
Hip Hop Artist
Byebye V6~
Welcome Home New Pony :P
would a capaciter help that situation?
![]() ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig http://www.myspace.com/moddedmustangz Modded Mustang's Song
MM's Resident Ricer
2006 Scion tC
13.001@113
I doubt it sounds just like his alt is going bad it might not be his subs the one he has just might be old
Yeah, definitely get a cap. Regardless though, your battery shouldn't drain that fast unless you have a 2000 watt amp. I would suggest driving it for a while with the subs disconnected and if the battery light comes on when you accelerate then its time for a new alternator.
![]() 1998 V6, wheels,intake,headlights, foglights, 2 kicker comp vr 12's |
agreed ^^
Sounds like your alternator is toast. If you have a rather large amp and subwoofer setup you probably want to consider getting a larger alternator to replace the stock one.
Do NOT waste your money on a capacitor. They do nothing useful. its a shitty bandaid for a much larger problem. Upgrade your alternator and battery.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
#10 | |
MM's Database Error
optima battery
better alternator problem solved
Woah slow down guys. I didn't plan on falling asleep after i posted this so i could post more info about the car. Ok
1. I got a new alt like in may 2. I have subs but their only powered by a 300W amp so i dont think that would have killed it. 3. How big an amp should i go with runing that and all the interior lighting and stuff?
2005 Torrid Red GTO m6
unhook the amp and sub
and drive with it. if it fixes it there ya go if it still does it ... well did you get the alternator with a ifetime warranty?
1996 Cobra To be sold... 2005 M6 Twin Turbo GTO Torrid Red Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps. |
Probly i mean i did buy it from Napa so most likely it does. But, it jsut started doin this and i think i (according to my friend) "buzzed" it while i was dikin around and lowered it capacity by runin it to hard. But does any one happen to know what the stock alt. # amps on the v6 are by any chance? Thanks
#15 | |
ok well this sounds like a problem with our chrage back wire not really the entire alternator like every one has suggested. look for any corrosion on your battery terminal and try chraging your battery. your alternator sounds too new to be causing this problem. and a normal alternator should be about 85 to 90 amps. just to be safe though i would take a little trip to auto zone and ask them to help you test it. and have them test the voltage of your battery to make sure its at 12.6. and a capacitor is not junk nor is it a cheap bandade to cover up a bigger problem. it most cases it can really help you when your running big power. but you seemed to have a small system so i dont suggest buying one until your really pushing some wattage. but still go down to autozone and have them check it. you could just have a bad charge back wire. try these things befor you go spending big money.
#16 | |
but when you were dikin around with it you could have burned out a diode in it now that i think about it.
#17 | |
MM's Database Error
Yep, i recall a forum i was on sometime ago where someone went into great detail explaining how a capacitor works in a car audio application, and why they dont work like you'd think they might and why they're a waste of money. Just go to any respectable car audio forum and ask them what they think
#19 | |
all a capacitor does is help out the battery by holding in stored energy and releasing it when the bass needs that extra bit of power that would normaly drian the battery to a bad spot. and it keep voltage spikes from occuring and smooths it out.
MM's Database Error
found the article...
FAQ- Why a cap is useless! - 3.8 Mustang Message Board
Threads Similar to: Uhh Help! (Alternator)
| Alternator? | jonnotch | 5.0 Mustangs | 4 | October 29th, 2007 07:25 PM |
| 3G alternator.... | Casper98GT | 5.0 Mustangs | 11 | October 2nd, 2007 05:16 PM |
| alternator | mustangman0001 | 5.0 Mustangs | 5 | September 20th, 2007 10:40 PM |
| alternator | 89mustanggt | 5.0 Mustangs | 5 | May 19th, 2006 08:43 AM |
