Clutch Cable And Adjuster Mechanism Help
Hi everyone,
I am in the process of removing the adjuster mechanism from my 99 v6. I've got the cable off and out, along with the quadrant, however I cannot for the life of me, figure out how to get the pedal bracket assembly out! Apparently there are 5 bolts holding it in, an I've gotten 3 of them out. Where are the other two? Do I have to remove the master cylinder and do the whole break fluid thing just to get the assembly out? Also, if anyone could tell me how to remove the pawl spring from the clutch pedal, I would appreciate it! btw: I am doing all this in an attempt to diagnose a certain "chattering" or vibration in the clutch pedal, which goes away simply by "pushing" the clutch pedal up, so im guessing its not a problem with the clutch itself. Thanks, Travis |
my clutch does the same thing ..it like squeaks and sounds like its vibrating but i just simply push in the clutch a little and it goes away
01 v6 true duals with 40 series flows and custom h pipe cold air intake http://www.myspace.com/xxarsonfreakxx (PERSONAL) http://www.myspace.com/vicious_racing (THE STANG FAMILY)
¡ʇsnq ɹo uʍop ǝpısdn
woah so im not alone? cool ...
sorry dude i can't find my chilton to save my life ... i know it would have the answers ...
you know what looking over the book ... the first thing you should have tried is pulling the pedal up towards the steering wheel as far as you can ... then depress the pedal to the floor ... if an audiable click is heard then it has adjusted its self...
honestly ... looking over the guide i would look into replacing the self adjusting unit its self ... and also it looks like the clutch pedal uses the whole pedal assy. as part of its linkage and shit ... meaning the pedal on the left has a pivoting rod that runs through the assy. to the passenger side of it and runs the cable back... i would suggest checking all the springs around the clutch pedal its self ... right at the top where the main part of the pedal meets other parts to create the assy.
99 Cobra
13.77 @ 102
![]() iTrader: 1 reviews
[ certain "chattering" or vibration in the clutch pedal, which goes away simply by "pushing" the clutch pedal up, so im guessing its not a problem with the clutch itself.
Thanks, Travis[/quote] Got a 96 GT doing the same thing. Was doing research this morning trying to find out the deal. Spec Stage 2 clutch init and just started this crap the other day. The pedal vibrates pretty violently at times! Did you figure out what the deal was with it yet? I don't have an adjustable cable set-up, yet...I may give that a try. Clutch is still holding strong, no noises, no slipping, just a chattery pedal! WTF????? |
Mine does that tooo!!!!!!!!!!!!!!!!!!!its mad annoying lol i think if you adjust the slack in the line it may go away cuz like Onemanzu said u press the pedal in a little and it goes away.. i put a zoom clutch in it when i pulled the motor but its done it since i bought the car.
![]() Gotta Get Lower
#7 | |
mine used to do it... i just adjusted the cable cause it had some slack. After adjusting everything cool you just need to drop it in N and press the clutch until firm again. Maybe thats what you need adjusting the slack
Threads Similar to: Clutch Cable And Adjuster Mechanism Help
| Steeda Clutch Adjustment Quadrant, Cable, Firewall Adjuster. | fallstar01 | Parts | 4 | August 26th, 2010 02:51 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 11:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 03:33 PM |
| upr clutch quadrant and fire wall adjuster | ujslost | Parts | 0 | April 19th, 2007 12:32 AM |
| Clutch quadrant and Firewall adjuster | ujslost | 96-98 | 4 | April 15th, 2007 08:39 PM |
