Discussing Short Block Time in the V6 Mustangs Forum. I am about to build a fresh Short Block. I'm about to send an ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Short Block Time
I'm about to send an 89 SC block to the machine shop to get dipped, punched out 30 over and some new cam bearings. After that it will be time to install brass freeze plugs and Clevite 77 Main bearings. Then I will drop in a 4.2L crank and some 351w eagle I beam forged rods, 8.5 Wiesco forged pistons, with zero gap rings. Final touch will be a better breathing cam and some LS1 beehive valve springs. After that back to the Dyno for an updated tune. I will most likely snap a few pictures as I go...................
2003 Mustang Mach1 1995 Thunderbird LX 4.6; 4R70W w/Jmod, 8.8 3.27 Tracloc 1995 Mustang 4.2; MPX Supercharger/25%OD, 4R70W w/Jmod, 8.8 3.73 Tracloc (343rwhp/420rwtq) |
Moderator
1989 MUSTANG LX 5.0
16.17@86.21(bone stock on street tires)
Holy shit!!! Thats sounds mean!
SUPPORT YOUR LOCAL HOOKERS....HUG A TOW TRUCK DRIVER! Donate to lxhatch@gmail.com |
SOUNDS SICK! DEFINATELY get some pics!
1999 Ford Mustang V6
couple of questions, i assume you are going with the 4.2 crank either because you bought the supercoupe block by itself or it came with the duracast crank? also if you are using a 89 block which oil pump do you plan on using? last, which shop do you plan on having the machine work done.. because i was debating on driving mine out to harrisonburg to CMRE?
...even fire and single cammin |
I have a 89 SC Block lying around, which I decided to use for this project. As for the 4.2 crank I got it for $198.74 (new) last week from Ford. As for the oil pump I am going to use a 95 timing chain cover and oil pump. The 95 NA timing cover uses the correct crank sensor and will accept a SC water pump.
cool, because i was gonna say from my understanding the 94-95 sc oil pumps flow much better (around 20%) and are a little stronger.
also is the 4.2L crank externally balanced? if so you should still be-able to re-use your 95's balancer and flywheel?
The 4.2 crank is internally balanced. The 95 NA 3.8 is an externally balanced so I cannot use the harmonic dampener and flexplate, but I have a harmonic dampener and flexplate from a 94 SC, which are for an internally balanced V6. Come to think of it I have a 94/95 SC timing chain cover and oil pump.
wasn't sure about the 4.2's... got both setups right now 99 externally and 01 neutral balanced harmonic dampners and flexlates. can you tell what year a supercoupe block is by looking at it? the one i have has a forged crank, but not sure about the year? castings, timing, block + crank, rear main
The block casting mark is on the driveriside of the block, near the back cylinder. Also there is one on the rear main cap. That looks like a 89-93 Block, as the 94-95 blocks had a windagetray.
E9 = 89
yeah the main cap says E9S ECA so 89 it is, thanks!
Threads Similar to: Short Block Time
| new short block | bobnasty | 99-04 | 0 | October 26th, 2007 08:47 AM |
| Short block or 4v | Badasstang281 | 99-04 | 17 | October 20th, 2007 06:16 AM |
| short block differs from a long block how? | mustangfox9091 | 5.0 Mustangs | 35 | September 26th, 2007 11:57 PM |
| short block vs long block? | caintcatchmyGT | 96-98 | 3 | July 22nd, 2007 10:47 PM |
| MMR Short Block vs DSS Short Block | superbeef1000 | 99-04 | 6 | September 20th, 2006 05:49 AM |
